Випадки вигоряння 12VHPWR
S0N1C
Авжеж всім нам відомо про надійність цього роз"єму, тому в цій темі будуть суто одиничні випадки його пошкодження. Вказуйте модель відекарти, використовуйте цитування(на випадок якщо джерело буде видалено) і посилання на джерело:
Модель
опис
посилання
Відправлено через 2 хвилини 1 секунду:
ASUS Rog Strix 4090 LC OC
I am beside myself. Yesterday I couldn’t get a get game to start for more than 3 minutes, today it was a different post code every time I tried. Admittedly, it was only 5 or 6, but 99 happened a couple of times in a row. So, dissembling had begun. A single tear rolled down the cheek when WireView was not letting go the way it should, as my heart knew before my mind did. Idk if the pictures are doing it justice, but the third pin from the left looks blue irl not silver.
Interestingly, input side of WV and output side of native cable are fine. I haven’t pulled the build apart further as I’m writing this as a distraction from my current emotional state. No need to let the wife & kid see, so an afternoon woobly pop on the deck while I assess if gaming is even worth it anymore.
Honestly, my guts want to blame the UE5 engine, and/or the “en-poop-ification” of you’ll own nothing rent everything and like it. It’s probably an irrational emotional response, being this mad & sad simultaneously at my age over a gpu is what my kid calls cringe. True, as this was my mid-life crisis expenditure. First built in November’23
7800x3d, Crosshair Gene, G.skill 2x32, 4tb T700, Rog Strix 4090 LC OC, Seasonic Prime TX-1300 3.0, OG WireView. No dongles. Does the AIO even matter here?
It’s been a hot minute since the last “I never thought the 12 volt hot power would happen to me posts…
Відправлено через 2 хвилини 24 секунди:
NVIDIA RTX 5090 FE
It happened to me with my 5090 FE on a Corsair SF1000i PSU. Cable on the PSU end was melting while one wire on the GPU end was starting to melt. Luckily, the 5090 FE didn't receive any damage.
I was curious and checked old cables on an old setup that I had with a 4090 FE and a Corsair HX1500i. The old cable had thermal discoloration on both ends.
I always made sure everything was fitted tight with no tight bends.
OverPow
А нафіга ?
S0N1C
для нащадків :gigi:
oversteve
перепис криворуких мажорів? :gigi:
Відправлено через 4 хвилини 32 секунди:
S0N1C: 08.08.2026 14:04 ASUS Rog Strix 4090 LC OC
а от тут вголосіну, у чувака згоріла приблуда дербауера за 100 євро, яка мала б запобігати прогару :lol:
MessiaH
S0N1C
не читай жёлтую прессу и реддит где в основном криворукие или дибилы, которые подключают такие карты к убогим всратым БП через кальмаров и ещё кидают одну косу на две клешни, особых проблем никаких с этим кабелем нет если не попадётся бракованная карта какая-нибудь или бракованный переходник, а лучше комплектные переходники вовсе не юзать, только нормальный кабель от нормального БП
S0N1C
Sapphire 9070xt nitro+
So my Sapphire 9070xt nitro+ started crashing entering games. Investigated and found this. I know this cable was installed correctly as I paid very close attention to it. It was definitely seated correctly. The card itself looks clean. Silver pins and no damage to the socket. Guess I'll find out if the card is damaged when I get a new adapter. These should be banned.
Another Failure
oversteve
S0N1C: 09.08.2026 10:49 Sapphire 9070xt nitro+
Another Failure
черговий погнутий перехідник у ніші Нітри, їх ще багато буде :learn:
dext
When one died on a 9070 XT I knew no-one was safe
Що зпроектоване горіти - то буде горіти :teacher:
Чому згорів wireview на 4090? Тому що новий стандарт ATX 3.1 покращує роз'єм (подовжує піни) ... на стороні ВК, і можливо на стороні БЖ, якщо дзеркальний.
Тому це покращення не стосується 40-серії, де всі є бета-тестерами минулого стандарту, новий БЖ/кабель/wireview тут не допоможе, фізично :rotate:
oversteve
dext: 09.08.2026 17:43 Чому згорів wireview?
тому що це китайське гівно, яке намагаються продати під видом чудоприблуди за багато грошей
S0N1C
Palit RTX 4080
Can I get a pat on the shoulder?
Edit : It's an RTX 4080 from Palit that I bought 4 years ago. Thought it says it on my flair but people keep asking...
Never thought it would happen to me.
S0N1C
RTX 3090 TI FE
I noticed some green corrosion on one of the cables and stupidly continued using it. Today I smelt burning and saw the damage on the connector so I shut the PSU down. The GPU looks ok so I am hoping it wasn't damaged.
This is a CableMod 3x8 12VHPWR cable that is at least two years old.
https://www.reddit.com/r/pcmasterrace/s/Hq9WxRou3f
kairo
Щось не зрозумів суть цієї теми. Перепис Реддіту? Так просто в пошук пишеш 12VHPWR melt та й читаєш.
S0N1C
RTX 5090
5090 has been disconnecting... I thought it was the power supply, but I think it may be the 12v pin cable... Is the cable done for?
https://www.reddit.com/r/pcmasterrace/c ... owerhouse/
S0N1C
:shuffle:
