Last of Us Part II Remastered потребуватиме GeForce RTX 4080 і Radeon RX 7900 XTX для 4K
man1242
Пропоную обговорити Last of Us Part II Remastered потребуватиме GeForce RTX 4080 і Radeon RX 7900 XTX для 4K
Тут могла быть шутка про фср 3.1 и смысл его существования если есть уже версия 4 но она будет очень не смешная
Lekrs
Норм вимоги.
kairo
Знову буде трешовий реліз із жахливою оптимізацією та купою крашів, чи в цей раз розробники постараються випустити нормальний порт?
The Last of Us Part I Benchmark Test & Performance Analysis Review
"If you've been looking at the Steam ratings of The Last of Us, you've been surprised by a "mostly negative" score. The negative reviews are not due to the gameplay, but due to various crashing issues. On first game launch, the title will start precompiling shaders, a lot of them, totaling 12 GB. This takes forever, even on a decent CPU, 10-20 minutes is not unexpected. What makes things worse is that this shader compilation will often crash, especially on GeForce cards, especially when you have less than 32 GB RAM. At least you don't have to start all over again, but launching the game ten or twenty times just to get to the main menu is really unacceptable. I wonder what the QA testers were doing all this time... Once you've made it into the game the game will crash sometimes (4x in my testing). The AMD Radeon driver also crashed several times during testing, and I've seen numerous reports of DLSS causing additional crashes, when enabled. The developers have already pushed out several game updates, and it seems that they are serious about fixing these problems quickly. Let's hope they can resolve them soon, so that people can enjoy this masterpiece of a game."
Геральт
man1242: 21.03.2025 12:36 Тут могла быть шутка про фср 3.1 и смысл его существования если есть уже версия 4 но она будет очень не смешная
Дійсно, не смішний жарт. Адже судячи з вимог, апскейли там не треба.
man1242
kairo: 21.03.2025 12:49 Знову буде трешовий реліз із жахливою оптимізацією та купою крашів, чи в цей раз розробники постараються випустити нормальний порт?
Проще так понял на пс5 пройти, спасибо сони что на пк порт цену не понизила :laugh:
Nortrom
На картинке XT, а не XTX
n+gibat[]r
Ну вот моя RTX4070 Ti Super и отыквилась :gigi:
А хотя нет, я же играю на 2К мониторе а не 4К :lol:
Tiufin
Йшов 2025 рік. Ігри все ще робили під 720р х 30фпс :D :insane:
Colonel
Більшість мають монітори 1080 р, а сучасні ігри виставляють системні вимоги під 2к чи 4к тепер не треба гадати на кавовій гущі, а яке залізо потрібно щоб грати на ультра в 1080 р.
vsx
тем кто смог достать 9070 тоже было не очень смешно
Lekrs
Colonel
Все більше переходять на 1440р. Враховуючи технології масштабування, в 1080р сенсу не має.
KimRomik
Всьо. Геймінг це тільки еліта :weep:
Bukakanga
аффтар новости не смог прочитать, что написяно на картинке. А там указана ХТ модель 7900й, а не ХТХ. Из чего заголовок сильно обманывает читателя
man1242
vsx: 21.03.2025 13:16
Ну так жадность не позволяет дать людям фср 3.5 условный с cnn моделью вместо фср 3, надо осуждать такое действие
kairo
Lekrs: 21.03.2025 13:18 Colonel
По статистиці Стім, майже 40% моніторів мають роздільну здатність вище 1080р. В першу чергу це 1440р - 30%.
man1242
Nortrom: 21.03.2025 13:07 Last of Us Part II Remastered потребуватиме GeForce RTX 4080 і Radeon RX 7900 XTX для 4K
Там только одна карта как 2,5 пс5 :laugh:
Colonel
Те що я знаю то люди переходять на більшу діагональ 24 чи 27 дюйма, а ось розширення залишається 1080 р. Залізо не тягне 2к - не у всіх є можливість купити топові відеокарти більшість сидить на середньобюджетних або бюджетних.
Tetronga
Colonel: 21.03.2025 13:12 Більшість мають монітори 1080 р, а сучасні ігри виставляють системні вимоги під 2к чи 4к тепер не треба гадати на кавовій гущі, а яке залізо потрібно щоб грати на ультра в 1080 р.
Ну то тому, що консосі мають таргет 4К. 1080 це пастген, причому вже пару років як. Тому і пишуть вимоги під 2-4К
Enjthesilence
Tetronga: 21.03.2025 13:41
ці "консолі в 4к" з нами в одній кімнаті?
