Нужен совет в настройке PPTP, на убунте.
- Main PID: 548 (pptpd)
CGroup: /system.slice/pptpd.service
|-548 /usr/sbin/pptpd --fg
|-720 pptpd [91.123.148.233:930F - 0180]
`-721 /usr/sbin/pppd local file /etc/ppp/pptpd-options 115200 10.10.10.1:10.10.10.5 ipparam 91.123.148.233 plugin /usr/lib/pptpd/pptpd-logwtmp.so
May 28 22:08:09 vvi249tbsmi pptpd[720]: CTRL: Starting call (launching pppd, opening GRE)
May 28 22:08:09 vvi249tbsmi pppd[721]: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded.
May 28 22:08:09 vvi249tbsmi pppd[721]: pppd 2.4.7 started by root, uid 0
May 28 22:08:09 vvi249tbsmi pppd[721]: Using interface ppp0
May 28 22:08:09 vvi249tbsmi pppd[721]: Connect: ppp0 <--> /dev/pts/1
May 28 22:08:13 vvi249tbsmi pppd[721]: peer from calling number 91.123.148.233 authorized
May 28 22:08:13 vvi249tbsmi pppd[721]: MPPE 128-bit stateless compression enabled
May 28 22:08:13 vvi249tbsmi pppd[721]: Cannot determine ethernet address for proxy ARP
May 28 22:08:13 vvi249tbsmi pppd[721]: local IP address 10.10.10.1
May 28 22:08:13 vvi249tbsmi pppd[721]: remote IP address 10.10.10.5
- ens3 Link encap:Ethernet HWaddr 52:54:00:60:f1:d6
inet addr:91.216.59.42 Bcast:91.216.59.255 Mask:255.255.255.0
inet6 addr: fe80::5054:ff:fe60:f1d6/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:197827 errors:0 dropped:1276 overruns:0 frame:0
TX packets:4926 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:30593276 (30.5 MB) TX bytes:905679 (905.6 KB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:160 errors:0 dropped:0 overruns:0 frame:0
TX packets:160 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:11840 (11.8 KB) TX bytes:11840 (11.8 KB)
ppp0 Link encap:Point-to-Point Protocol
inet addr:10.10.10.1 P-t-P:10.10.10.5 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1
RX packets:177 errors:0 dropped:0 overruns:0 frame:0
TX packets:7 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:3
RX bytes:11402 (11.4 KB) TX bytes:94 (94.0
