[Україна, Харків] Для геймерів та ентузіастів: SIM-RACING; PHANTEKS Evolv X2 Matrix; Hyte X50; Lian Li B4; HAVN HS 420; SSUPD; Jonsbo DS916; CableMod; Endgame Gear; PHANTEKS T30; Lian Li UNI FAN TL / SL-INF LCD FLEX...
Объявления о продаже
freemannew
Alex-the-Cat Добрый вечер, ответил в ЛС
freemannew
Завтра поступление на склад
По ценам спрашивайте в личку, в теме некоторые цены неактуальны из-за курса
Coolgate Dual 120mm (CG-240)
Coolgate Triple 120mm (CG-360)
Koolance QD3 Male Quick Disconnect No-Spill Coupling, Compression for 10mm x 16mm (3/8in x 5/8in) Black
Koolance QD3 Female Quick Disconnect No-Spill Coupling, Compression for 10mm x 16mm (3/8in x 5/8in) Black
Phobya Noise Destructor
Laing DDC-1T 12V
Alphacool VPP655 - single edition (D5)
Alphacool HF D5 TOP - Black Acetal G1/4
EK-CSQ Fitting 10/13mm G1/4 - Black
EK-CSQ Fitting 10/16mm G1/4 - Nickel
EK Water Blocks EK-PSC Adapter 45° G1/4 Nickel
EK Water Blocks EK-PSC Adapter 90° G1/4 Nickel
Alphacool HF 3-way connection terminal G1/4 inner thread - Deep Black
Phobya TPC 4x Fan- or Pump-Controller 30Watt
Phobya Balancer 150 black matt
Phobya Balancer 250 Black Matt
Alphacool Repack Single Bayres 5,25" - Rev. 2
Gelid ICY VISION rev.2
Gelid ICY Vision-A
Gelid Silent 12 PWM (FN-PX12-15)
Phobya NB-eLoop 1600rpm - Bionic Fan
Noiseblocker NB-eLoop B12-2 Bionic fan 1300rpm
Corsair SP120 PWM High Performance Edition 120mm
Masterkleer tubing PVC 16/10mm (3/8"ID) UV-active blue Box 3,3 метра
Masterkleer tubing PVC 16/10mm (3/8"ID) UV-active black Box 3,3 метра
Masterkleer tubing PVC 16/10mm (3/8"ID) UV-active red Box 3,3 метра
Masterkleer tubing PVC 16/10mm (3/8"ID) UV-active white Box 3,3 метра
Thermometer with digital display - blue (термопара)
Gelid GC-02 Thermal Compound 7
Phobya 2 Component Thermal Glue
Revoltec CCFL 30cm Twin set Rev. 2 RED
Watercool HEATKILLER® GPU-X? Core LC
Востаннє редагувалось 18.03.2014 18:10 користувачем freemannew, всього редагувалось 1 раз.
OlegFl
Be Quiet! Silent Wings 2 120mm х2 и 140mm х1 интересуют, если есть возможность их завезти, и сколько они будут стоить?
freemannew
Александр Одесса
Спасибо, получил :up: :) :)
freemannew
Александр Одесса :beer:
tberro
Сдравствуйте. нужны 2 кулера Power Logic PLD08010S12HH на msi r6870 hawk twin frozr iii. С кажите есть ли они у вас в наличии?
freemannew
Spleen
Доброй ночи!
Подскажите, пожалуйста:
Существуют ли в природе подобные водянки:
1). Что б занимали 3-4 отсека 5.25"
2). Полная бесшумность помпы и минимальный шум вертушек
3). Эффективность выше чем у Zalman CNPX10Performa
4). Низкая стоимость (пока психологически не готов больше 1000-1200 грн выложить)
5). Какая-нибудь подсветочка или прозрачные шланги, etc
БУДЕТ ТОЛЬКО ПРОЦ (i5-4670K, планирую скальпирование и умеренный разгон), в будущем видео вешать на эту водянку не собираюсь !
Спасибо.
freemannew
Добрый день, если это требование к одной системе, то нет. Бесшумность, высокая эффективность, подсветка это да, по поводу слотов 5,25, нет, по сумме денег так же нет.
Spleen
Я бы смотрел в сторону SilverStone Tundra TD02, да только дизайн ужасный и разместить её особо негде..
freemannew
Да там дизайна того... можно выкрасить в черный цвет, будет лучше.
Если не влазит, поставьте хороший воздух.
Spleen
freemannew:Да там дизайна того... можно выкрасить в черный цвет, будет лучше.
У меня в корпусе есть 4 дырки для вывода наружу трубок охлаждения и есть внутри корпуса 3, а, при необходимости, даже 4 отсека свободных 5.25"
Сзади же просто посадочное место под 120/140 мм кулер но, так понимаю, это ничтожно мало для радиатора.
freemannew
Одной секции будет мало, как расположить, внешне или внутренне придумать можно, дело тут не в этом. Сумма денег слишком мала.
Spleen
freemannew:Одной секции будет мало, как расположить, внешне или внутренне придумать можно, дело тут не в этом. Сумма денег слишком мала.
Каким минимумом нужно располагать ?
freemannew
отписал в лс
cybermouse
Здравствуйте, а какая актуальная цена на Phanteks PH-TC14PЕ - Black
freemannew
Добрый вечер, ответил в лс
Junimemo
Добрый вечер, интересует:
Gelid Cable 8 Pin (PCI-E) 30cm Red x2 (Есть такие?)
Gelid Cable 24 Pin (ATX) 30cm Red
Gelid Cable 8 Pin (EPS) 30cm Red
Phobya Shroud & decoupling 140mm (7mm) x2
Резиновые гвозди Phobya x2 (x2 комплекта)
Также интересуют вертушки 140мм, очень тихие нужны(сейчас Fractal Silent r2 стоят, шумно, корпус fractal xl r2), что можете предложить?
freemannew
Доброго, ответил в ЛС
