Флудилка (часть 3)
Разговоры обо всем
Закрыто
Sanьka
Продолжение флудилки
начало viewtopic.php?f=16&t=225508
В данной теме действуют правила аналогично остальным.
В т.ч. запрещено :
1. Обсуждение политики
2. Торговля во всех ее проявлениях
3. Пропаганда наркотиков, алкоголя!!! и т.п.
Ну понеслась....
WakeMe
анти__бот
Да, чтобы легче прокачать было такую балду.
анти__бот
WakeMe
а плотность там какая, ну расстояния между пластинами?
WakeMe
анти__бот
Product Information
The MO-RA3 represents an uncompromising improvement of the successful MO-RA2. Its cooling performance has been increased, even above that of the powerful predecessor. More than 28 meters of tubing and 2.5 square meters of fins speak for themselves. The cooling fluid now flows in a four-time parallel layout through 72 tubes. The fins of the MO-RA3 have been optimized specifically for low-rpm fans. Their enormous surface and effective geometry guarantee excellent cooling performance.
The highly parallel layout and the new flow-optimized connection block ensure a low flow-resistance, despite the large size of the heat-exchanger. The connection block improves flexibility as well by providing G1/4“ threads in three directions.
The MO-RA3 Core LC is shipped without casing. It is meant for individual designs and may be used actively or passively. Four M4 threads per side may be used for self-made fan grills or for mounting it on a case. The MO-RA3 fan grills cannot be mounted on the MO-RA3 Core LC.
The MO-RA3 is produced in Europe. Development and final assembly happen in Germany, like the manufacturing of most of its components.
Specifications:
Material: Copper (tubes), aluminum (fins)
Dimensions (L x W x H): 405 x 378 x 63 mm
Weight: approx. 5000 g
Pressure tested: 5 bar
Threads: 6x G ¼” (DIN ISO 228-1)
Отправлено спустя 3 минуты 13 секунд:
Следующую возьму в обвесе с лапками, чтобы поставил и все, не мудрить с ее креплением потом. Просто тут подвернулось выгодно, теперь месяц приходится собирать детали для перехода на внешку :insane:
Kozakevich
проставлял в поздравительной теме всем плюсики, а они почти все исчезли. обидна!!! :(
анти__бот
Kozakevich
всм?
Отправлено спустя 45 секунд:
WakeMe
выгодно, это за сколько?
WakeMe
анти__бот
2к
Барбарис
Kozakevich, выложил фото своего ящика в теме "Фотки системников" и сразу минус, то есть человек прям сидит и ждет поста или бота создал(не знаю можно ли так). Нечего тут переживать.
Dark-seer
Барбарис
потомучто мусорка а не корпус наверное :dontknow:
Kozakevich
Барбарис: Нечего тут переживать.
Да тут не в минусах дело :) в системе исчезли мои плюсы! :gigi:
Отправлено спустя 29 секунд:
К слову говоря, почти вся поздравительная тема без минусов кроме одного поста
Барбарис
Kozakevich, в смысле не отображается зеленая стрелка? То фигня, периодически такой глюк бывает - надо обновить страницу и поставиь снова.
Dark-seer, мне как-то пофиг, я его для себя сделал и мне нравится. Сам факт, я опубликовал пост и за секунду - две что перешел на страницу там уже минус. Это прям тайминги, как в КС.
Grinnie Jax
Психодельчик подъехал.
Sanьka
Барбарис
Кинь ссылку, что за сборка такая .
Барбарис
Sanьka, на корпус? Так в фотках системников -
viewtopic.php?f=13&t=52&start=13440
DarkJoney
Подскажите, в какой теме можно узнать нынче "рыночную" цену на видеокарту? GT640, хочу узнать совета экспертов рынка за сколько ее ставить, не хочу продешевить. :)
Grinnie Jax
DarkJoney:GT640
Для музейного экспоната ещё молода, для майнинга не годится, не знаю даже :think:
DarkJoney
Grinnie Jax
Ну вот я тоже)))
Dark-seer
обычная затычка для вывода изображения, 300-500 гривен не больше
DarkJoney
Dark-seer
Ты хотел сказать 2300-2500, если перевести на рыночный?))))
Volodimir
DarkJoney:Ты хотел сказать 2300-2500, если перевести на рыночный?
К сожалению, - НИТ! Такое только для вывода картинки, поэтому что 210-710, что 630-640 - 20 баксов. Надежды обрушены. 2500 - это минимум играбельные нвидии 950, радики 560...
Отправлено спустя 2 минуты 3 секунды:
Grinnie Jax:Психодельчик подъехал.
как-то слишком обнадёживает. Прям жду.
Dark-seer
DarkJoney: ↑ 28.03.2021 15:11 Dark-seer
за 100$ можно взять подушатаную 1063, ты о чем?
Закрыто
