Чувствуете ли вы разницу между 40-50-60 фпс?
Jumper007
ToshaUA
http://forum.overclockers.ua/viewtopic.php?f=2&t=58930 - Производительность CPU в LinX - сбор результатов
http://forum.overclockers.ua/viewtopic.php?f=31&t=94148 - AIDA64 GPGPU Benchmark
http://forum.overclockers.ua/viewtopic.php?f=31&t=2783 - 3DMark Vantage: обсуждаем и делимся результатами
http://forum.overclockers.ua/viewtopic.php?f=31&t=75115 - Unigine Valley Benchmark 1.0
Пройди это все и скриншоты сюда положи.
ToshaUA
Intel(R) LINPACK 64-bit data - LinX 0.6.4
Current date/time: Thu Nov 21 21:12:26 2013
CPU frequency: 2.430 GHz
Number of CPUs: 1
Number of cores: 4
Number of threads: 4
Parameters are set to:
Number of tests : 1
Number of equations to solve (problem size) : 10000
Leading dimension of array : 10008
Number of trials to run : 20
Data alignment value (in Kbytes) : 4
Maximum memory requested that can be used = 800844256, at the size = 10000
============= Timing linear equation system solver =================
Size LDA Align. Time(s) GFlops Residual Residual(norm)
10000 10008 4 7.518 88.6984 9.603002e-011 3.386116e-002
10000 10008 4 7.772 85.8058 9.603002e-011 3.386116e-002
10000 10008 4 7.675 86.8908 9.603002e-011 3.386116e-002
10000 10008 4 7.710 86.4931 9.603002e-011 3.386116e-002
10000 10008 4 7.731 86.2636 9.603002e-011 3.386116e-002
10000 10008 4 7.722 86.3545 9.603002e-011 3.386116e-002
10000 10008 4 7.729 86.2794 9.603002e-011 3.386116e-002
10000 10008 4 7.749 86.0585 9.603002e-011 3.386116e-002
10000 10008 4 7.836 85.1067 9.603002e-011 3.386116e-002
10000 10008 4 7.807 85.4242 9.603002e-011 3.386116e-002
10000 10008 4 7.763 85.9035 9.603002e-011 3.386116e-002
10000 10008 4 7.780 85.7186 9.603002e-011 3.386116e-002
10000 10008 4 7.733 86.2420 9.603002e-011 3.386116e-002
10000 10008 4 7.748 86.0739 9.603002e-011 3.386116e-002
10000 10008 4 7.745 86.1040 9.603002e-011 3.386116e-002
10000 10008 4 7.856 84.8889 9.603002e-011 3.386116e-002
10000 10008 4 7.872 84.7117 9.603002e-011 3.386116e-002
10000 10008 4 7.736 86.2050 9.603002e-011 3.386116e-002
10000 10008 4 7.761 85.9236 9.603002e-011 3.386116e-002
10000 10008 4 7.750 86.0518 9.603002e-011 3.386116e-002
Performance Summary (GFlops)
Size LDA Align. Average Maximal
10000 10008 4 86.0599 88.6984
End of tests
Добавлено через 30 секунд:
Температура Процессора макс 63
Number of CPUs: 1
Number of cores: 4
Number of tests : 1
End of tests
Последний раз редактировалось ToshaUA 21.11.2013 19:34, всего редактировалось 1 раз.
viperest1
А навіщо так багато букв?
ToshaUA
Как фото добавить?
Jumper007
ToshaUA
Скриншоты умеешь делать ?
Открываешь на раб столе КПУ-З, окно проги с температурой Линкс, проходишь тест.
Нажимаешь кнопку на клаве PrtSc-SysRq , потом открываешь пейнт и там Ctrl+V, сохраняешь как .jpeg , открываешь http://piccy.info/ и туда загружаешь скрин, а ссылку полученную сюда пишешь.
Хотя уже сейчас видно что линкс пишет 2,4 Ггц частоту проца
какая частота в кпу-з во время теста ?
ToshaUA
http://piccy.info/view3/5472394/8f5b491 ... 36f68aa17/" target="_blank
Добавлено через 41 секунду:
http://piccy.info/view3/5472397/f3a6c25 ... d5aa5e9d2/" target="_blank
Во время теста
Во время теста
Kimmuriel
Я чувствую разницу между 50 и 300 в кс го
Jumper007
ToshaUA
У проца и памяти показатели в норме, давай качай 2 бенча последних там будет видно еще и видео.
Hauptmann
Свою карту на другом компе проверял? Системный БИОС перешивался? В каком режиме работает слот PCI-E?
Скорее всего, судя из выше сказанного и если 3 сторонние карты ведут себя так же "неправильно", то проблема в материнке. Хорошо если на уровне коммуникаций, а не NB. Или банально в софте.
ToshaUA
http://piccy.info/view3/5472716/9174b40 ... 8c228db19/" target="_blank
Карту на другом компе не проверял, но проверял на своем компе gtx 660 7850 ситуация не менялась(
Мать менял год назад, в магазе сказали что ситуация изменится в лучшую сторону, тоесть тормозов когда смотрю на большие локации не будет, тогда же докупил 8 гб оперативки. Ситуация не поменялась.
С того момента в компе поменял все!
С процессора до БП.
Не менял только корпус и Монитор.
С процессора до БП.
Jumper007
ToshaUA
Вооот, уже есть за что зацепиться. Общие баллы и макс фпс соответствуют железу, а вот минимальный фпс жестко проседает. Возможно на карте просаживается напряжение на гпу в нагрузке, или это в бп глюк и не тянет в макс нагрузке карту, или с портом пси-е на матери не все ок.
Делай марк вантаж пока что.
п.с. и качай МСИ Афтербурнер + комбустор.
ToshaUA
Кстати у меня драйвера 13.11 9.2 бета.
И тормоза на больших локациях или когда смотрю в сторону где много полигонов или как их там, объектов у всех играх.
Бп менял тоже, но взял б/у на 600В.
От у меня корпус очень старый, но продув есть ( боковую крышку снял ).
SaDisT
я вот сегодня Rivals запустил и 30фпс их стандартный не заметил особо так что каждому своё
ToshaUA
http://piccy.info/view3/5477272/2a5a73c ... 9c213501f/" target="_blank
http://piccy.info/view3/5477275/5210445 ... e847e0ee1/" target="_blank
http://piccy.info/view3/5477279/76298fc ... aeccdabc1/" target="_blank
Вот 3d mark 11
Видеокарта во время теста не нагружалась судя по световому индикатору.
Вот 3d mark 11
Andrey2005
видео, которое я спрашивал полторы недели назад, будет или нет?
ToshaUA
ок залью
Jumper007
ToshaUA
Нормально все нагружалось, результат нормальный.
Делай 3DMark Vantage.
Еще проверь что происходит с напряжением на гпу, мониторинг есть в
MSI Afterburner или в ASUS GPU Tweak, включи мониторинг и делай Unigine Valley Benchmark (или Комбустор), потом смотри на температуры, загрузку, напряжение.
ToshaUA
Нагрузка скачет то 99 то 63.
Добавлено через 2 минуты 19 секунд:
В комбустере
Температура 64-65
Добавлено через 1 минуту 7 секунд:
А где в афтербурнере напряжения смотреть?
Добавлено через 32 минуты 40 секунд:
Вот поиграл в бф4 15 минут.
Fan speed выставил на 41.
Играл с показателем фпс м заметил что иногда при 65 иногда притормаживает, а иногда и при 55 плавно.
Добавлено через 2 минуты 50 секунд:
http://piccy.info/view3/5478223/d7f2191 ... fc18c1043/" target="_blank
http://piccy.info/view3/5478228/a416544 ... c6d38e331/" target="_blank
После игры.
В комбустере
Температура 64-65
После игры.
ToshaUA
3d mark Vattage зависает. Помогает только ребут.
