Змагаймось в нашій команді Folding@Home!
Обсуждение программ
Artistus
Digital Artist
Alexsandr
Не пробував віддалене керування через telnet?
Тут опції.
Alexsandr
еще не пробовал. Что с лидерами расчетов случилось? бигжбы бьются?
di2di
Alexsandr
маленькая реорганизация компьютерного парка...
Sh@G
Это пипец, а не клиент на линуксе :banghead: Ну никак не хочет получать бигжабы, а если что-то и удаётся получить - то выходит вот такая ошибка:
19:47:29:Switching to user fahclient
19:47:29:Trying to access database...
19:47:29:Database locked
19:47:29:Enabled folding slot 00: PAUSED smp:8
19:47:29:Started thread 2 on PID 2985
19:47:29:Started thread 4 on PID 2985
19:47:29:Started thread 5 on PID 2985
19:47:29:Started thread 6 on PID 2985
19:47:29:Started thread 7 on PID 2985
19:47:57:Started thread 8 on PID 2985
19:47:57:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
19:48:04:Slot 00 unpaused
19:48:05:Connecting to assign3.stanford.edu:8080
19:48:06:Connecting to assign3.stanford.edu:8080
19:48:06:News: Welcome to Folding@Home
19:48:06:Assigned to work server 128.143.199.96
19:48:06:Requesting new work unit for slot 00: READY smp:8 from 128.143.199.96
19:48:06:Connecting to 128.143.199.96:8080
19:48:07:Slot 00: Downloading 1.69MiB
19:48:11:Slot 00: Download complete
19:48:11:Received Unit: id:00 state:DOWNLOAD project:7139 run:0 clone:19 gen:68 core:0xa3 unit:0x00000049fbcb017c4d77867a87342c3c
19:48:11:Starting Unit 00
19:48:11:Running core: /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Cor ... FahCore_a3 -dir 00 -suffix 01 -lifeline 2985 -version 701 -checkpoint 15 -np 8
19:48:11:Started core on PID 3011
19:48:11:Started thread 9 on PID 2985
19:48:11:FahCore 0xa3 started
19:48:11:FahCore, running Unit 00, returned: FAILED_3 (255)
19:48:11:Sending unit results: id:00 state:SEND project:7139 run:0 clone:19 gen:68 core:0xa3 unit:0x00000049fbcb017c4d77867a87342c3c
19:48:11:Connecting to 128.143.199.96:8080
19:48:12:Server responded WORK_QUIT (404)
19:48:12:WARNING: Server did not like results, dumping
19:48:12:Cleaning up Unit 00
Config-файл имеет вид:
<config>
<!-- Logging -->
<verbosity v='5'/>
<!-- Network -->
<proxy v=':8080'/>
<!-- User Information -->
<passkey v='ххх'/>
<team v='156571'/>
<user v='Sh@G'/>
<!-- Folding Slots -->
<slot id='0' type='SMP'>
<client-type v='bigadv'/>
<max-packet-size v='big'/>
<max-units v='1'/>
<memory v='5120'/>
<next-unit-percentage v='95'/>
<pause-on-start v='true'/>
</slot>
</config>
После удаления всех файлов в папке /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a3.fah/ и /var/lib/fahclient/work таки удалось получить задание и начать его считать, но мне кажется, что это обычное задание, и самое удивительное - каждый шаг считается столько же (порядка 4 минут), сколько и на частоте 2,66 (сейчас 3,8).
Вот выдержка из лога:
20:10:03:Connecting to assign3.stanford.edu:8080
20:10:03:News: Welcome to Folding@Home
20:10:03:Assigned to work server 128.143.199.96
20:10:03:Requesting new work unit for slot 00: READY smp:8 from 128.143.199.96
20:10:03:Connecting to 128.143.199.96:8080
20:10:04:Slot 00: Downloading 1.69MiB
20:10:07:Slot 00: Download complete
20:10:07:Received Unit: id:00 state:DOWNLOAD project:6972 run:0 clone:24 gen:55 core:0xa3 unit:0x0000003bfbcb017c4d80d0ce86db6e54
20:10:07:Downloading core from http://www.stanford.edu/~pande/Linux/AMD64/Core_a3.fah" target="_blank
20:10:07:Connecting to http://www.stanford.edu:80" target="_blank
20:10:07:WARNING: FahCore type in core package seems to be in wrong byte order.
20:10:07:FahCore a3: Downloading 2.56MiB
20:10:13:FahCore a3: 27.79%
20:10:19:FahCore a3: 61.69%
20:10:25:FahCore a3: 96.04%
20:10:25:FahCore a3: Download complete
20:10:25:Valid core signature
20:10:25:Unpacked 5.98MiB to cores/www.stanford.edu/~pande/Linux/AMD64/Cor ... FahCore_a3
20:10:25:Starting Unit 00
20:10:25:Running core: /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Cor ... FahCore_a3 -dir 00 -suffix 01 -lifeline 2985 -version 701 -checkpoint 15 -np 8
20:10:25:Started core on PID 4633
20:10:25:FahCore 0xa3 started
20:10:25:Started thread 16 on PID 2985
20:10:26:Unit 00:
20:10:26:Unit 00:*------------------------------*
20:10:26:Unit 00:Folding@Home Gromacs SMP Core
20:10:26:Unit 00:Version 2.27 (Dec. 15, 2010)
20:10:26:Unit 00:
20:10:26:Unit 00:Preparing to commence simulation
20:10:26:Unit 00:- Looking at optimizations...
20:10:26:Unit 00:- Created dyn
20:10:26:Unit 00:- Files status OK
20:10:26:Unit 00:- Expanded 1768974 -> 1957708 (decompressed 110.6 percent)
20:10:26:Unit 00:Called DecompressByteArray: compressed_data_size=1768974 data_size=1957708, decompressed_data_size=1957708 diff=0
20:10:26:Unit 00:- Digital signature verified
20:10:26:Unit 00:
20:10:26:Unit 00:Project: 6972 (Run 0, Clone 24, Gen 55)
20:10:26:Unit 00:
20:10:26:Unit 00:Assembly optimizations on if available.
20:10:26:Unit 00:Entering M.D.
20:10:32:Unit 00:Mapping NT from 8 to 8
20:10:32:Unit 00:Completed 0 out of 500000 steps (0%)
20:14:26:Unit 00:Completed 5000 out of 500000 steps (1%)
20:18:10:Unit 00:Completed 10000 out of 500000 steps (2%)
20:22:14:Unit 00:Completed 15000 out of 500000 steps (3%)
20:26:01:Unit 00:Completed 20000 out of 500000 steps (4%)
20:30:05:Unit 00:Completed 25000 out of 500000 steps (5%)
20:34:33:Unit 00:Completed 30000 out of 500000 steps (6%)
20:39:10:Unit 00:Completed 35000 out of 500000 steps (7%)
20:43:39:Unit 00:Completed 40000 out of 500000 steps (8%)
Artistus
Digital Artist
Sh@G
Просто містика якась. :spy:
Воно повинно качати ядро а5, а в тебе а3 чогось качається. Пробуй на паузу, збережи з насторойками для великих жаб і не забудь обрати 8! або більше потоків (в твоєму конфігу того не видно), вийди, ядра і завдання повидаляй і знов запусти. ;)
ShaggY
Заметил баг в 7-м клиенте, если при отправке задания, клиент или комп виснет, можно забыть об обчках которые насчитали. Ибо он теряет задание, если я правильно понимаю, потом просто новое качает((
Sh@G
:jump: :pray: Я заставил эту скотину наконец-то работать как следует и получать бигжабы :super: Правда дали жабу, я помнится такую ещё не считал (Project: 2684 (Run 7, Clone 22, Gen 64)), уж больно много уходит времени на один шаг - порядка 52минут в среднем... :(
Сейчас вот с такими параметрами запускается: "Running core: /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Cor ... FahCore_a5 -dir 00 -suffix 01 -lifeline 1709 -version 701 -checkpoint 15 -np 8"
Итоговый конфиг выглядит вот так - выдержка из лога:
05:16:34: <user v='Sh@G'/>
05:16:34:
05:16:34: <!-- Work Unit Control -->
05:16:34: <dump-after-deadline v='true'/>
05:16:34: <max-queue v='16'/>
05:16:34: <max-units v='0'/>
05:16:34: <next-unit-percentage v='99'/>
05:16:34:
05:16:34: <!-- Folding Slots -->
05:16:34: <slot id='0' type='SMP'>
05:16:34: <client-type v='bigadv'/>
05:16:34: <cpus v='8'/>
05:16:34: <max-packet-size v='big'/>
05:16:34: <max-units v='1'/>
05:16:34: <next-unit-percentage v='95'/>
05:16:34: <pause-on-start v='true'/>
05:16:34: </slot>
05:16:34:</config>
Artistus
Digital Artist
Sh@G зміни кількість потоків після початку рахунку завдання до кількості видимих ядер в системі (або увімкни НТ).
52 хвилини - то щось дуже довго для і7.
Мій Фен Х4 3,6ГГц рахує його за 45-50 хв.
Правда, в мене було завдання 2686.
Sh@G
Artistus:Sh@G зміни кількість потоків після початку рахунку завдання до кількості видимих ядер в системі (або увімкни НТ).
Ну у меня НТ итак всегда включен и кол-во ядер указывал соответствующее действительности :-)
Сейчас у меня Estimated TPF: 49 mins 51 secs (это после того, как комп считал без нагрузки на него с моей стороны; до этого параллельно с FAH я пытался "допиливать" установленный дистрибутив :gigi: )
ShaggY
У всех нормально отправляються задания посчитаные на 7-м клиенте, а то уже 2 посчитало и не может послать, и больше для видяхи не хочет грузить((
Alexsandr
Судя по очкам, задания отправляются нормально.
ShaggY
Видать сервак глючил... Уже отправилось.
Artistus
Digital Artist
На днях вийде новий лінух, який працюватиме ще на пару % швидше. Чекаємо! ;)
Добавлено через 32 минуты 54 секунды:
Народ, де зник аванпост Ovreclockers.ua Folding? Швидкість впала!
Дайте жару, бо в такому темпі ми до 200 місця до кінця року точно не доповземо.
-stan-
Давайте жару!!!
Я когда из дому на неделю уезжаю и то комп включеным оставляю, даже научил мать проверять подключение)
Artistus:Народ, де зник аванпост Ovreclockers.ua Folding
Походу все на биткойн перелезли, продались... :weep:
Zhekawork
-stan-:Давайте жару!!!
наверное все ушли бухать на праздники, как и я тоже
-stan-
Zhekawork
ну ушли и ладно, а комп зачем выключать :shuffle:
Шаженла
ужас реанимировал я видеокарту всё я теперь я щитаю
Artistus
помоги мне какие то простые задания приходят хотя я всё правильно ввёл :weep: :weep:
бухать всегда можно тока комп пожалуйста не надо вырубать :shuffle:
Zhekawork
-stan-
Вера не позволяет, я почему то боюсь оставлять электроприборы без присмотра более чем на 1 день ;)
Добавлено через 4 минуты 22 секунды:
Денис97
Не прими за обиду ;) , но не мог бы ты, хотя бы, стараться писать без ошибок и со знаками препинания :beer:
Добавлено через 1 минуту 45 секунд:
Денис97:ужас реанимировал я видеокарту всё я теперь я щитаю
Artistus
Скажи, что тебе нужно помочь и покажи лог, может я помогу.
-stan-
Zhekawork
ну тогда нужно хотя-бы раз в день дома появляться :)
Zhekawork
-stan-:Zhekawork
бухал три дня :gigi: , кроме меня жена может только интернет вкл. нажать :(
