SSD. Налаштування, оптимизація, вирішення проблем
Allex...
Последний раз редактировалось almazmusic 16.12.2010 03:42, всего редактировалось 1 раз.
pops0417
тут еще лучше:
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000a 100 100 000 Old_age Always - 0
2 Throughput_Performance 0x0005 100 100 050 Pre-fail Offline - 0
3 Spin_Up_Time 0x0007 100 100 050 Pre-fail Always - 0
5 Reallocated_Sector_Ct 0x0013 100 100 050 Pre-fail Always - 0
7 Unknown_SSD_Attribute 0x000b 100 100 050 Pre-fail Always - 0
8 Unknown_SSD_Attribute 0x0005 100 100 050 Pre-fail Offline - 0
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 1012
10 Unknown_SSD_Attribute 0x0013 100 100 050 Pre-fail Always - 0
12 Power_Cycle_Count 0x0012 100 100 000 Old_age Always - 181
167 Unknown_Attribute 0x0022 100 100 000 Old_age Always - 0
168 Unknown_Attribute 0x0012 100 100 000 Old_age Always - 83
169 Unknown_Attribute 0x0013 100 100 010 Pre-fail Always - 524289
170 Unknown_Attribute 0x0013 100 100 010 Pre-fail Always - 0
173 Unknown_Attribute 0x0012 001 001 000 Old_age Always - 23579754436270
175 Program_Fail_Count_Chip 0x0013 100 100 010 Pre-fail Always - 0
180 Unused_Rsvd_Blk_Cnt_Tot 0x0033 100 100 020 Pre-fail Always - 264
192 Power-Off_Retract_Count 0x0012 100 100 000 Old_age Always - 148
194 Temperature_Celsius 0x0022 066 066 030 Old_age Always - 34 (Min/Max 33/34)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
231 Temperature_Celsius 0x0033 010 010 005 Pre-fail Always - 100
233 Media_Wearout_Indicator 0x0032 100 100 000 Old_age Always - 657272883456
234 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 865599128448
240 Unknown_SSD_Attribute 0x0013 100 100 050 Pre-fail Always - 0
241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 707208567
242 Total_LBAs_Read 0x0032 100 100 000 Old_age Always - 527076038
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
anatolikostis
попробуй планку памяти другую
jimbo
неси по гарантии и не покупай трешак, собраный из отходов производства нормальных ссд
Shpoker
лолpops0417:231 Temperature_Celsius 0x0033 010 010 005 Pre-fail Always - 100
Отправлено спустя 34 секунды:
отпал радиатор внутри диска?))
pops0417
Да, веселый экземпляр
А все же, что могло пойти не так? Первые 10 сек. стартует, выдает инфу, геометрия в норме...
Понятно что его в морг. Да и на органы не очень-то и пустишь.
Но интересно, блин, покопаться
snapdragon999
Подскажите кто шарит ,хром установлен на ssd ,скачка файлов настроена на HDD ,при скачивании файлов отнимается место и на SSD ,потом возвращается ,то есть проходит и через ссд тоже ,можно как то данное неподобство устранить чтоб не кушало мне ссд ,файлы то большие бывают фильмы всякие ?
Slavon84
Ребята, подскажите, есть ли у TEAM Group фирменная утилита для работы с ихними SSD (SMART, прошивка etc)
andrey.nk
если рейд 0 создать на двух разных SSD с разными скоростными характеристиками и обьемом (120гб и 128гб "номиналы") - нормально работать будет?
Inspiring
Подключил новый ссд (второй в профиле), будет использоваться под игрушки и хлам, что выбрать GPT или MBR ?
Отправлено спустя 1 минуту 41 секунду:
Всем спасибо выбрал ГПТ
Отправлено спустя 10 минут :
Может кому интересно - SSD CRUCIAL MX300 525GB
Vizavi
Привет всем.
Буду обновлять железяку и в связи с тем что в Ryzen есть только 4 свободных PCI линии поставить 2 NVME не получиться . (Изначально хотел один под систему, второй на игры).
Остается вариант купить NVME один по жирнее и разбить на два логических диска. На одном из которых будет операционистка, на другом игрушки.
В связи с этим назрел вопрос - а не будет ли падений производительности при таком раскладе ?
Imper
Vizavi
Конечно будет, лучше сделайте так:
1 - для ОС, второй для программ, третий для игр, четвертый для видео и тд.
Vizavi
Шутки по 100 закончились, остались только по 20 ?Imper:Vizavi
jimbo
даже если ты при этом будешь писать видео в 60-100мегабит на него - ты ничего в игре не заметишь.Vizavi:В связи с этим назрел вопрос - а не будет ли падений производительности при таком раскладе ?
Andrey2005
И что это даст?Vizavi:купить NVME один по жирнее и разбить на два логических диска
Sergey771
думаю два разделаAndrey2005:И что это даст
Юрій1989
Imper:Vizavi
Keyso
Подскажите пожалуйста как лучше оптимизировать ОС для SSD Samsung 850 PRO 256 с помощью Мэджикан?
Интерисуют все 8 пунктов расширенных параметров.
Попытался найти в теме но так и не получилось, простите если этот вопрос уже обсуждался...
И еще парамтры ОР, как лучше сделать? Оно хочет почти 24 Гига
Skeptik
Никак не оптимизировать - если ос хотя бы семерка с сервис-паком, то она сама умеет все что нужно.Keyso:как лучше оптимизировать ОС для SSD
По задачам. Если трим есть - то ор не особо-то и нужно...Keyso:И еще парамтры ОР, как лучше сделать?
Keyso
Благодарю!
Ось 7sp1 x64, так и поступлю
G power
Друг сказал что его системник не запускается и ругается на отсутствие бут дивайса..зашел я к нему с заготовленной виндофлешкой но не тут то было..
диск определяется под именем PS3109S9 и размером 20 МБ..
сам с таким не сталкивался,вот и прошу совета у знаюших..в урну его или что то еще можно сделать.
