переклад:fix-list for the patch
- All Weapons Bronze Insignia requiring an unobtainable bronze star for the tracer dart – requirement removed.
- Improved Hit registration made through several fixes and some of the hitboxes themselves have been changed. This will increase the accuracy of guns.
- Blue box chat window removed
- The 2 second immunity when spawning/being revived will now be immediately removed either by firing, zooming, or any movement (move, crouch, jump). A Spawning Player can still orient passively in the Game World..
- 3D vision fixed.
- Fixed slug shotgun zoom crosshair on PC so they better represent the long range accuracy. Crosshairs now close more on PC, similar to consoles.
- Reduced slug shotgun hip accuracy to require zooming for consistent long range accuracy. Hip accuracy is now on par with the semi automatic weapons.
- Fixed a bug on PC where the G3 would do less damage than intended.
- Fixed VADS turning sensitivity on PC so it performs like the ZU23.
- Reduced VADS push back and damage to balance it with the ZU23.
- Fixed a bug where vehicle countermeasures would fail to remove tracer darts at high speed.
- Reduced the reload time for vehicle countermeasures.
- Slightly increased the AT4's damage vs armor to emphasize its anti vehicle role while keeping it balanced vs armor.
- Increased the AT4’s top speed and acceleration so users spend less time exposed when firing.
- Increased the AT4's splash damage so it competes with other AT weapons vs infantry. The AT4 still has the least splash damage of all AT weapons.
- Reduced the splash damage of the Carl Gustav to bring it in line with other explosive weapons. The Carl Gustav still has the most splash damage of all AT weapons.
- Increased the 1 shot kill range of the M95 body shot to counter its lower rate of fire.
- Fixed a bug with the SVU that gave it better close range damage than other semi auto weapons.
- Reduced all weapon damage to the MCOM by 50%.
- Fixed an C4 vs MCOM exploit on Atacama Desert.
- Fixed a bug with FOV when aiming the M1911.
- Lowered the close range damage of the AN94 to highlight its long range role.
- Increased the accuracy of the F2000 on the move to highlight its role as a mobile AR.
- Increased the close range damage of the shotguns to give them a greater advantage vs slugs.
- Slightly lowered the damage of the M60 to balance its accuracy advantage vs other LMG's.
- Slightly lowered the damage of the MG3 at close range to balance it with other high rate of fire weapons.
- Slightly increased the damage of the UH60.
Добавлено спустя 2 минуты 47 секунд:* Ачивка "бронзовые звёзды на всём оружии" теперь не требует заработать бронзовую звезду на Маячковом пистолете, которы=ую заработать невозможно.
* Поправлена регистрация попаданий во врага, сделано несколько изменений, это повысит общую точность оружия.
* 2х секундный иммунитет у врага после того, как врага возродил медик теперь сбрасывается, если враг начнёт двигаться или стрелять.
* Поправлены некоторые баги с NVidia 3D Vision
* Поправлен прицел для дробовиков с жеканом, теперь из них будет удобнее стрелять вдаль.
* Уменьшена точность стрельбы из дробовика с жеканом от бедра. Теперь жекан будет предназначен и исключительно удобен только для стрельбы на дальние расстояния.
* Поправлен баг с g3, когда она наносила чересчур слабый урон.
* VADS теперь управляется легче и наносит такой же урон как и Zu23.
* AT4 теперь обладает большим уроном, большим радиусом поражения, большей скоростью полёта ракеты и маневренность ракеты теперь тоже будет лучше.
* Убавлен радиус поражения у Carl Gustav
* м95 теперь убивает с одного выстрела на больших расстояниях, чем раньше.
* Поправлен баг с СВУ, когда она наносила чересчур высокий урон на ближних дистанциях.
* Теперь всё оружие наносит на 50% меньше урона МКОМам.
* Поправлена проблема на Атакаме, когда некоторые мкомы без проблем уничтожались с помощью с4.
* Поправлен баг, когда FOV изменялся, когда мы прицеливались из M1911.
* Понижен урон Абакана на ближних дистанциях, чтобы подчеркнуть, что Абакан предназначен для стрельбы на дальние расстояния.
* Повышена точность F2000.
* Повышен урон дробовиков на ближних дистанциях.
* Понижен урон м60.
* понижен урон МГ3.
* Повышен урон миниганов в UH-60 BlackH
на даний момент качається у мене оновлення.., ІА сервери швидкості жаліють. Дуже цікаво подивитися на АН-94..., боюсь що буде
