Проблемы с ATI Radeon HD 2600XT
X_plode
На картинках ниже гляньте, левые текстуры вылезают. Во всех нормальных играх. На скринах Street Legal2, а еще такое наблюдал в GTA SA, Ex machina meredian 113 и т.д. Прикладываю DxDiag. Раньше такого не было, началось совсем недавно. Дрова пробовал и 9.4 и 9.3, а сейчас вообще на 8.12 сижу, прогресса ноль. Температура GPU в обычном режиме 55, в играх 70-80. А еще было VPU recover, тоже на скрине.
Добавлено спустя 1 минуту 38 секунд:
System Information
Time of this report: 5/12/2009, 15:01:41
Machine name: GROMOZEKA
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp.080413-2111)
Language: Russian (Regional Setting: Russian)
System Manufacturer: System Manufacter
System Model: System Product Name
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 5200+, MMX, 3DNow (2 CPUs), ~2.5GHz
Memory: 2048MB RAM
Page File: 378MB used, 3561MB available
Windows Dir: C:WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found. DirectDraw test results: All tests were successful. Direct3D 7 test results: All tests were successful. Direct3D 8 test results: All tests were successful. Direct3D 9 test results: All tests were successful.
Sound Tab 1: DirectSound test results: All tests were successful.
Music Tab: DirectMusic test results: All tests were successful.
Input Tab: No problems found.
Network Tab: No problems found. DirectPlay test results: All tests were successful.
Display Devices
Card name: ATI Radeon HD 2600 XT
Manufacturer: ATI Technologies Inc.
Chip type: ATI Radeon Graphics Processor (0x9588)
DAC type: Internal DAC(400MHz)
Device Key: EnumPCIVEN_1002&DEV_9588&SUBSYS_20031787&REV_00
Display Memory: 512.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6925 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 2/26/2009 01:41:10, 325120 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: Mini VDD: ati2mtag.sys
Mini VDD Date: 2/26/2009 02:58:57, 3565568 bytes
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: All tests were successful.
D3D7 Test Result: All tests were successful.
D3D8 Test Result: All tests were successful.
D3D9 Test Result: All tests were successful.
Name: ATI Radeon HD 2600 XT
Device ID: PCIVEN_1002&DEV_9588&SUBSYS_20031787&REV_004&154B9167&0&0078
Driver: C:WINDOWSsystem32DRIVERSati2mtag.sys, 6.14.0010.6925 (Russian), 2/26/2009 02:58:57, 3565568 bytes
Driver: C:WINDOWSsystem32DRIVERSati2erec.dll, 1.00.0000.0018 (English), 2/26/2009 00:37:46, 53248 bytes
Driver: C:WINDOWSsystem32ati2dvag.dll, 6.14.0010.6925 (English), 2/26/2009 01:41:10, 325120 bytes
Driver: C:WINDOWSsystem32ati2cqag.dll, 6.14.0010.0413 (English), 2/26/2009 00:32:05, 626688 bytes
Driver: C:WINDOWSsystem32Ati2mdxx.exe, 6.14.0010.2495 (English), 2/26/2009 01:29:41, 26112 bytes
Driver: C:WINDOWSsystem32ati3duag.dll, 6.14.0010.0647 (English), 2/26/2009 01:16:45, 3817984 bytes
Driver: C:WINDOWSsystem32ativvaxx.dll, 6.14.0010.0218 (English), 2/26/2009 00:59:31, 2670080 bytes
Driver: C:WINDOWSsystem32atiicdxx.dat, 1/26/2009 21:55:37, 182995 bytes
Driver: C:WINDOWSsystem32ativva5x.dat, 2/26/2009 00:58:44, 3107788 bytes
Driver: C:WINDOWSsystem32ativva6x.dat, 2/26/2009 00:58:44, 887724 bytes
Driver: C:WINDOWSsystem32amdpcom32.dll, 6.14.0010.0023 (English), 2/26/2009 00:44:29, 49664 bytes
Driver: C:WINDOWSsystem32atiadlxx.dll, 6.14.0010.1032 (English), 2/26/2009 00:38:47, 126976 bytes
Driver: C:WINDOWSsystem32ativvaxx.cap, 2/26/2009 00:58:55, 151824 bytes
Driver: C:WINDOWSsystem32ATIDDC.DLL, 6.14.0010.0008 (English), 2/26/2009 01:26:17, 53248 bytes
Driver: C:WINDOWSsystem32atitvo32.dll, 6.14.0010.4200 (English), 2/26/2009 00:38:37, 17408 bytes
Driver: C:WINDOWSsystem32ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 20:01:04, 24064 bytes
Driver: C:WINDOWSsystem32ati2evxx.exe, 6.14.0010.4222 (English), 2/26/2009 01:27:41, 602112 bytes
Driver: C:WINDOWSsystem32ati2evxx.dll, 6.14.0010.4178 (English), 2/26/2009 01:29:15, 155648 bytes
Driver: C:WINDOWSsystem32atipdlxx.dll, 6.14.0010.2550 (English), 2/26/2009 01:30:02, 204800 bytes
Driver: C:WINDOWSsystem32Oemdspif.dll, 6.15.0006.0004 (English), 2/26/2009 01:29:49, 155648 bytes
Driver: C:WINDOWSsystem32ati2edxx.dll, 6.14.0010.2514 (English), 2/26/2009 01:29:32, 43520 bytes
Driver: C:WINDOWSsystem32atikvmag.dll, 6.14.0010.0098 (Russian), 2/26/2009 00:40:20, 475136 bytes
Driver: C:WINDOWSsystem32atifglpf.xml, 8/31/2007 18:20:49, 7167 bytes
Driver: C:WINDOWSsystem32ATIDEMGX.dll, 2.00.3343.30075 (Russian), 2/26/2009 01:42:32, 442368 bytes
Driver: C:WINDOWSsystem32aticaldd.dll, 6.14.0010.0227 (English), 2/26/2009 00:30:01, 3227648 bytes
Driver: C:WINDOWSsystem32aticalrt.dll, 6.14.0010.0227 (English), 2/26/2009 00:32:59, 45056 bytes
Driver: C:WINDOWSsystem32aticalcl.dll, 6.14.0010.0227 (English), 2/26/2009 00:32:53, 45056 bytes
Driver: C:WINDOWSsystem32atibrtmon.exe, 2.00.0000.0000 (English), 10/21/2008 22:51:43, 118784 bytes
Driver: C:WINDOWSsystem32atiok3x2.dll, 6.14.0010.8543 (Russian), 2/26/2009 00:35:08, 290816 bytes
Driver: C:WINDOWSsystem32atioglxx.dll, 6.14.0010.8543 (English), 2/26/2009 01:30:15, 11841536 bytes
Driver: C:WINDOWSsystem32atiiiexx.dll, 6.14.0010.4006 (English), 2/26/2009 01:09:44, 307200 bytes
Driver: C:WINDOWSatiogl.xml, 12/29/2008 23:35:28, 15485 bytes
Driver: C:WINDOWSsystem32ATIODCLI.exe, 1.00.0000.0001 (English), 10/21/2008 21:40:00, 45056 bytes
Driver: C:WINDOWSsystem32ATIODE.exe, 1.00.0000.0001 (English), 10/21/2008 21:40:00, 81920 bytes
Driver: C:WINDOWSsystem32ATIODCLI.exe.manifest, 9/30/2008 01:22:29, 529 bytes
Driver: C:WINDOWSsystem32ATIODE.exe.manifest, 10/4/2008 01:48:01, 527 bytes
Вкладення
.jpg
Ass_Itch
похоже на проблемы с памятью. попробуй даунклокнуть и проверить.
Serfer
у меня когда-то из-за драйверов такое было. Удали драйвер, почисть программой Driver Sweeper...
pavlan
знакомо....... поставил самые новые дрова, розагнал-- не знаю что помогло но артефакты и галы пропали!) ошибка на последней (картинке) у меня вообще каждые 5 минут вылазала. из того что видно на картинке похоже на переразгон памяти (у мя такое было) а раз не разгонял, то походу просто как-то мехонически её повредил. не ранял? проверь на механические повреждения. а ещё убидись на 100% что нет вирусов, тоже может быть. директ икс последний ставил? и надеюсь 10-тый под xp не ставил?
LuckyHawk
Скорее всего дрова...
Serfer:Удали драйвер, почисть программой Driver Sweeper...
+1 а еще лучше переставить винду наново, и попробовать разные версии дров. У меня такие дела были как раз на 8.12 когда у меня стояла 2600хт, мне помогли новые на то время дрова 8.3.
X_plode
У меня clock в bios стоит 1.54 это не дофига ли? Сам ничего не выставлял, в catalyst'e стоят стандартные GPU - 800Mhz и память 700Mhz. Подскажите какой стандартный clock. Drive sweeper попробую и завтра напишу.
X_plode
Drive sweeper не помог, пробовал версию 1.5.5 и 2.0.0 beta. Систему переустанавливал с форматом дикска С. Проблема осталась. Месяца 2 назад менял термопасту на проце видюхи, работала отлично, а сейчас смотрел три угла сколоты примерно на 0,2-0,4мм. Может быть из за этого проблема, хотя кажется программная ошибка.
Serfer
X_plode:три угла сколоты примерно на 0,2-0,4мм
уууу... вполне может того... короче играм быть конец
X_plode
Походу все 4 угла сколоты - фото..
Тогда подскажите, что важнее 128 или 256 бит, GDDR3 или GDDR4, объем памяти 512 или 1000Мб? И какую посоветуте в пределах 130$?
Вкладення
Kolian
X_plode
viewtopic.php?t=4663
pavlan
X_plode
прикольно. как до такого дожился, ну ты и гонищ. тяжковато будет продать, возьмут только на детали( на рынке) в следующий раз будь осторожнее при смене пасты.
X_plode
Kolian спасибо.
pavlan Не буду продавать, т.к. видюха испорчена. В помойку или в комп на работе.
pavlan
X_plode
:idea: можа гденибудь на работе поменять видюшку, там всёравно никто не рубает разницы и не заметят))))))))) так сказать будеш хитрецом! :)
Kolian
pavlan
Дальнейшее развитие темы о подмене карт - в ЛС.
liberakatnem
Востаннє редагувалось 04.09.2009 13:53 користувачем liberakatnem, всього редагувалось 1 раз.
LuckyHawk
liberakatnem
Старые версии дров и ССС пробовал?
