Оновлення закладає фундамент для оновлення в кінці року
Годно, треба ставити
The 1.2 CKD setting only defines whether CKD is enabled. If the CPU IMC doesn't support it, it still won't be supported. Setting it to enabled won't prevent support. You can refer to the hardware information; this is a secret the motherboard manufacturer didn't disclose.
