Процессоры AMD Ryzen 7000-й серии (Raphael\Zen 4\5 nm\AM5)
Dark_Angel3000
ASTON
Налаштування з бiоса
[2023/01/13 22:36:37]
Ai Overclock Tuner [AEMP]
AEMP [DDR5-5600 38-38-38-76-1.25V-1.25V]
eCLK Mode [Asynchronous mode]
BCLK1 Frequency [100.0000]
BCLK2 Frequency [100.0000]
Memory Frequency [DDR5-6400MHz]
FCLK Frequency [2133 MHz]
Core Performance Boost [Auto]
CPU Core Ratio [Auto]
Core VID [Auto]
CCX0 Ratio [Auto]
CCX0 Ratio [Auto]
Dynamic OC Switcher [Auto]
GPU Boost [Auto]
Tcl [30]
Trcd [38]
Trp [38]
Tras [30]
Trc [36]
Twr [48]
Refresh Interval [60380]
Trfc1 [500]
Trfc2 [465]
Trfcsb [417]
Trtp [24]
TrrdL [6]
TrrdS [4]
Tfaw [16]
TwtrL [16]
TwtrS [4]
TrdrdScl [5]
TrdrdSc [1]
TrdrdSd [7]
Trdrddd [8]
TwrwrScl [15]
TwrwrSc [1]
TwrwrSd [11]
TwrwrDd [8]
Twrrd [6]
Trdwr [18]
IBUF_LPWR_MODE [Auto]
ADDR_CMD_MODE [Auto]
M_ORDERING [Auto]
S_COL_WIDTH [Auto]
MC_SVA_TRIM0 [Auto]
MC_SVA_TRIM1 [Auto]
MC_SVA_TRIM2 [Auto]
Proc CA Drive Strength [Auto]
Proc Data Drive Strength [Auto]
CPU On-Die Termination [Auto]
DRAM Data Drive Strength [Auto]
Rtt Nom Wr [Auto]
Rtt Nom Rd [Auto]
Rtt Wr [Auto]
Rtt Park [Auto]
Rtt Park Dqs [Auto]
Power Down Enable [Auto]
Memory Context Restore [Auto]
UCLK DIV1 MODE [UCLK=MEMCLK]
Bank Swap Mode [Auto]
Mem Over Clock Fail Count [Auto]
Medium Load Boostit [Auto]
Precision Boost Overdrive [Enabled]
Precision Boost Overdrive Scalar [Auto]
CPU Boost Clock Override [Auto]
Per-Core Boost Clock Limit [Auto]
Platform Thermal Throttle Limit [Auto]
Curve Optimizer [All Cores]
All Core Curve Optimizer Sign [Negative]
All Core Curve Optimizer Magnitude [10]
GFX Curve Optimizer [Auto]
VRM Initialization Check [Enabled]
CPU Load-line Calibration [Auto]
CPU Current Capability [Auto]
CPU Current Reporting Scale [Auto]
Core Voltage Suspension [Auto]
CPU VRM Switching Frequency [Auto]
VRM Spread Spectrum [Auto]
CPU Power Duty Control [T.Probe]
CPU Power Phase Control [Auto]
VDDSOC Load-line Calibration [Auto]
VDDSOC Current Capability [Auto]
VDDSOC Current Reporting Scale [Auto]
VDDSOC Switching Frequency [Auto]
VDDSOC Power Phase Control [Auto]
DRAM Current Capability [Auto]
DRAM Switching Frequency [Auto]
DRAM Power Phase Control [Extreme]
MISC Switching Frequency [Auto]
Performance Bias [Auto]
Clock Spread Spectrum [Auto]
BCLK1 Amplitude [Auto]
BCLK1 Slew Rate [Auto]
BCLK2 Amplitude [Auto]
BCLK2 Slew Rate [Auto]
1.8V PLL Voltage [Auto]
1.8V Standby Voltage [Auto]
Misc_ALW [Auto]
Chipset0 VDD Voltage [Auto]
Chipset1 VDD Voltage [Auto]
CPU 3.3V [Auto]
DDR_testA [Auto]
DDR_testB [Auto]
SMU_Comp1 [Auto]
SMU_Comp2 [Auto]
SMU_Comp3 [Auto]
R1 [Auto]
R2 [Auto]
R3 [Auto]
Sense MI Skew 1 [Auto]
Sense MI Skew 2 [Auto]
Sense MI Skew 3 [Auto]
Sense MI Skew 4 [Auto]
Raise RComp [Auto]
Algorithm 1 [Auto]
Algorithm 2 [Auto]
Algorithm 3 [Auto]
Cooler Efficiency Customize [Keep Training]
Cooler Re-evaluation Algorithm [Normal]
Optimism Scale [100]
CPU Core Voltage [Auto]
CPU SOC Voltage [Auto]
CPU VDDIO / MC Voltage [Manual Mode]
- VDDIO Override [1.40010]
Misc Voltage [Auto]
VDDP Voltage [1.200]
High DRAM Voltage Mode [Auto]
DRAM VDD Voltage [1.40000]
DRAM VDDQ Voltage [1.40000]
PMIC Voltages [Sync All PMICs]
SPD HUB VLDO (1.8V) [Auto]
SPD HUB VDDIO (1.0V) [Auto]
Memory VDD Voltage [1.40000]
Memory VDDQ Voltage [1.40000]
Memory VPP Voltage [Auto]
Memory Voltage Switching Frequency [Auto]
Memory Current Capability [Auto]
Security Device Support [Enable]
SHA256 PCR Bank [Enabled]
Pending operation [None]
Platform Hierarchy [Enabled]
Storage Hierarchy [Enabled]
Endorsement Hierarchy [Enabled]
Physical Presence Spec Version [1.3]
Disable Block Sid [Disabled]
Firmware TPM switch [Enable Firmware TPM]
Erase fTPM NV for factory reset [Disabled]
PSS Support [Enabled]
NX Mode [Enabled]
SVM Mode [Disabled]
Above 4G Decoding [Enabled]
Resize BAR Support [Enabled]
SR-IOV Support [Disabled]
Legacy USB Support [Enabled]
XHCI Hand-off [Enabled]
USB Mass Storage Driver Support [Enabled]
USB FLASH DRIVE RMAP [Auto]
U32G2_C3 [Enabled]
U32G2_4 [Enabled]
U32G2X2_C6 [Enabled]
U32G2_8 [Enabled]
U32G2_9 [Enabled]
U32G2_10 [Enabled]
U32G1_E1 [Enabled]
U32G1_E2 [Enabled]
U32G1_E3 [Enabled]
U32G1_E4 [Enabled]
USB12 [Enabled]
USB13 [Enabled]
USB14 [Enabled]
USB15 [Enabled]
USB16 [Enabled]
USB17 [Enabled]
U32G2X2_C18 [Enabled]
U32G2_20 [Enabled]
U32G2_21 [Enabled]
U32G2_22 [Enabled]
U32G2_23 [Enabled]
Network Stack [Disabled]
Device [N/A]
SATA Controller(s) [Disabled]
NVMe RAID mode [Disabled]
SMART Self Test [Enabled]
Restore AC Power Loss [Last State]
ErP Ready [Disabled]
Max Power Saving [Disabled]
Power On By PCI-E [Disabled]
Power On By RTC [Disabled]
PCIEX16_1 Bandwidth Bifurcation Configuration [Auto Mode]
PCIEX16_2 Bandwidth Bifurcation Configuration [PCIE X8 Mode]
USB Audio Controller [Enabled]
Wi-Fi Controller [Enabled]
Bluetooth Controller [Enabled]
When system is in working state [All On]
Q-Code LED Function [Auto]
When system is in sleep, hibernate or soft off states [Aura Off]
Intel LAN Controller [Enabled]
USB power delivery in Soft Off state (S5) [Enabled]
U32G2_C3 Type C Power Mode [Auto]
Alteration Mode Switch [PCIE Link Speed]
ASMedia Storage Controller [Enabled]
Windows Hot-plug Notification [Disabled]
ASPM Support [Disabled]
PCIEX16_1 Link Mode [Auto]
PCIEX16_2 Link Mode [Auto]
M.2_1 Link Mode [Auto]
Chipset_1 Link Mode [Auto]
M.2_2 Link Mode [Auto]
M.2_3 Link Mode [Auto]
Chipset_2 Link Mode [Auto]
PCIEX1 Link Mode [Auto]
M.2_4 Link Mode [Auto]
Primary Video Device [PCIE Video]
Integrated Graphics [Disabled]
UMA Frame Buffer Size [Auto]
Global C-state Control [Auto]
IOMMU [Auto]
SMT Control [Auto]
L1 Stream HW Prefetcher [Auto]
L2 Stream HW Prefetcher [Auto]
L1 Stride Prefetcher [Auto]
L1 Region Prefetcher [Auto]
L2 Up/Down Prefetcher [Auto]
Core Watchdog Timer Enable [Disabled]
Platform First Error Handling [Auto]
Opcache Control [Auto]
Streaming Stores Control [Auto]
Local APIC Mode [Auto]
ACPI _CST C1 Declaration [Auto]
MCA error thresh enable [Auto]
SMU and PSP Debug Mode [Auto]
PPIN Opt-in [Auto]
Enhanced REP MOVSB/STOSB [Enabled]
REP-MOV/STOS Streaming [Enabled]
Xtrig7 Workaround [Auto]
SNP Memory (RMP Table) Coverage [Auto]
SMEE [Auto]
Action on BIST Failure [Auto]
PAUSE Delay [Auto]
Memory interleaving [Auto]
Memory interleaving size [Auto]
DRAM map inversion [Auto]
Location of private memory regions [Auto]
ACPI SRAT L3 Cache As NUMA Domain [Auto]
Disable DF to external downstream IP Sync Flood Propagation [Auto]
Disable DF sync flood propagation [Auto]
Freeze DF module queues on error [Auto]
DF Cstates [Auto]
PSP error injection support [False]
Active Memory Timing Settings [Auto]
Processor CK drive strengths [Auto]
Processor CA drive strengths [Auto]
Processor CS drive strengths [Auto]
Dram ODT impedance RTT_NOM_WR [Auto]
Dram ODT impedance RTT_NOM_RD [Auto]
Dram ODT impedance RTT_WR [Auto]
Dram ODT impedance RTT_PARK [Auto]
Dram ODT impedance DQS_RTT_PARK [Auto]
Processor ODT impedance [Auto]
Processor DQ drive strengths [Auto]
Dram DQ drive strengths [Auto]
Disable Memory Error Injection [Auto]
TSME [Auto]
Data Scramble [Auto]
Chipselect Interleaving [Auto]
Address Hash Bank [Auto]
Address Hash CS [Auto]
Address Hash Subchannel [Auto]
BankSwapMode [Auto]
DFE Read Training [Auto]
DRAM PDA Enumerate ID Programming Mode [Auto]
TX DFE Taps [Auto]
PPT Control [Auto]
MBIST Enable [Auto]
PCIe ARI Support [Auto]
PCIe All Port ECRC [Auto]
Advanced Error Reporting (AER) [Auto]
PCIe ARI Enumeration [Auto]
PSPP Policy [Auto]
UMA Version [Auto]
GPU Host Translation Cache [Auto]
NB Azalia [Auto]
Audio IOs [Auto]
PCIe loopback Mode [Auto]
TDP Control [Auto]
PPT Control [Auto]
Thermal Control [Auto]
TDC Control [Auto]
EDC Control [Auto]
PROCHOT Control [Auto]
Fan Control [Auto]
VDDP Voltage Control [Auto]
Infinity Fabric Frequency and Dividers [Auto]
FEATURE FCLK DPM [Auto]
SyncFifo Mode Override [Auto]
CPU Temperature [Monitor]
CPU Package Temperature [Monitor]
MotherBoard Temperature [Monitor]
VRM Temperature [Monitor]
Chipset 1 Temperature [Monitor]
Chipset 2 Temperature [Monitor]
T_Sensor Temperature [Monitor]
Water In T Sensor Temperature [Monitor]
Water Out T Sensor Temperature [Monitor]
DIMM A1 Temperature [Monitor]
DIMM A2 Temperature [Monitor]
DIMM B1 Temperature [Monitor]
DIMM B2 Temperature [Monitor]
CPU Fan Speed [Monitor]
CPU Optional Fan Speed [Monitor]
Chassis Fan 1 Speed [Monitor]
Chassis Fan 2 Speed [Monitor]
Chassis Fan 3 Speed [Monitor]
Chassis Fan 4 Speed [Monitor]
Water Pump+ Speed [Monitor]
AIO Pump Speed [Monitor]
Flow Rate [Monitor]
CPU Core Voltage [Monitor]
12V Voltage [Monitor]
5V Voltage [Monitor]
3.3V Voltage [Monitor]
CPU VDDIO / MC Voltage [Monitor]
HYDRANODE Fan Association [Enabled]
CPU Fan Q-Fan Control [PWM Mode]
CPU Fan Profile [Full Speed]
Chassis Fan 1 Q-Fan Control [Auto Detect]
Chassis Fan 1 Profile [Manual]
Chassis Fan 1 Q-Fan Source [Water Out T Sensor]
Chassis Fan 1 Step Up [Level 0]
Chassis Fan 1 Step Down [Level 0]
Chassis Fan 1 Speed Low Limit [200 RPM]
Chassis Fan 1 Point4 Temperature [40]
Chassis Fan 1 Point4 Duty Cycle (%) [100]
Chassis Fan 1 Point3 Temperature [35]
Chassis Fan 1 Point3 Duty Cycle (%) [60]
Chassis Fan 1 Point2 Temperature [32]
Chassis Fan 1 Point2 Duty Cycle (%) [45]
Chassis Fan 1 Point1 Temperature [30]
Chassis Fan 1 Point1 Duty Cycle (%) [30]
Chassis Fan 2 Q-Fan Control [Auto Detect]
Chassis Fan 2 Profile [Manual]
Chassis Fan 2 Q-Fan Source [Water Out T Sensor]
Chassis Fan 2 Step Up [Level 0]
Chassis Fan 2 Step Down [Level 0]
Chassis Fan 2 Speed Low Limit [200 RPM]
Chassis Fan 2 Point4 Temperature [40]
Chassis Fan 2 Point4 Duty Cycle (%) [100]
Chassis Fan 2 Point3 Temperature [35]
Chassis Fan 2 Point3 Duty Cycle (%) [55]
Chassis Fan 2 Point2 Temperature [32]
Chassis Fan 2 Point2 Duty Cycle (%) [40]
Chassis Fan 2 Point1 Temperature [30]
Chassis Fan 2 Point1 Duty Cycle (%) [25]
Chassis Fan 3 Q-Fan Control [Auto Detect]
Chassis Fan 3 Profile [Manual]
Chassis Fan 3 Q-Fan Source [MotherBoard]
Chassis Fan 3 Step Up [Level 0]
Chassis Fan 3 Step Down [Level 0]
Chassis Fan 3 Speed Low Limit [200 RPM]
Chassis Fan 3 Point4 Temperature [75]
Chassis Fan 3 Point4 Duty Cycle (%) [100]
Chassis Fan 3 Point3 Temperature [70]
Chassis Fan 3 Point3 Duty Cycle (%) [70]
Chassis Fan 3 Point2 Temperature [60]
Chassis Fan 3 Point2 Duty Cycle (%) [40]
Chassis Fan 3 Point1 Temperature [50]
Chassis Fan 3 Point1 Duty Cycle (%) [30]
Chassis Fan 4 Q-Fan Control [Auto Detect]
Chassis Fan 4 Profile [Manual]
Chassis Fan 4 Q-Fan Source [Water Out T Sensor]
Chassis Fan 4 Step Up [Level 0]
Chassis Fan 4 Step Down [Level 0]
Chassis Fan 4 Speed Low Limit [200 RPM]
Chassis Fan 4 Point4 Temperature [40]
Chassis Fan 4 Point4 Duty Cycle (%) [100]
Chassis Fan 4 Point3 Temperature [35]
Chassis Fan 4 Point3 Duty Cycle (%) [60]
Chassis Fan 4 Point2 Temperature [32]
Chassis Fan 4 Point2 Duty Cycle (%) [45]
Chassis Fan 4 Point1 Temperature [30]
Chassis Fan 4 Point1 Duty Cycle (%) [30]
Water Pump+ Q-Fan Control [PWM Mode]
Water Pump+ Profile [Full Speed]
AIO Pump Q-Fan Control [Auto Detect]
AIO Pump Profile [Manual]
AIO Pump Q-Fan Source [Water Out T Sensor]
AIO Pump Step Up [Level 0]
AIO Pump Step Down [Level 0]
AIO Pump Speed Low Limit [Ignore]
AIO Pump Point4 Temperature [40]
AIO Pump Point4 Duty Cycle (%) [100]
AIO Pump Point3 Temperature [35]
AIO Pump Point3 Duty Cycle (%) [60]
AIO Pump Point2 Temperature [32]
AIO Pump Point2 Duty Cycle (%) [46]
AIO Pump Point1 Temperature [30]
AIO Pump Point1 Duty Cycle (%) [22]
Launch CSM [Disabled]
OS Type [Other OS]
Secure Boot Mode [Custom]
Fast Boot [Enabled]
Next Boot after AC Power Loss [Fast Boot]
Boot Logo Display [Disabled]
POST Report [2 sec]
Bootup NumLock State [On]
Wait For 'F1' If Error [Enabled]
Option ROM Messages [Force BIOS]
Interrupt 19 Capture [Disabled]
AMI Native NVMe Driver Support [Enabled]
Setup Mode [Advanced Mode]
BIOS Image Rollback Support [Enabled]
Publish HII Resources [Disabled]
Flexkey [Safe Boot]
Setup Animator [Disabled]
Load from Profile [3]
Profile Name [tmp]
Save to Profile [1]
DIMM Slot Number [DIMM_A2]
Download & Install ARMOURY CRATE app [Disabled]
Download & Install MyASUS service & app [Disabled]
Special Display Features [Disabled]
D3Cold Support [Disabled]
Discrete GPU _DSM Function A [Disabled]
Discrete GPU _DSM Function B [Disabled]
NVIDIA DGPU Power Enable [Disabled]
Non-Eval Discrete GPU Support [Enabled]
Discrete GPU HPD Circuitry [OR Circuitry]
Discrete GPU's USB Port [Keep Default Setting]
Discrete GPU's SSID/SVID [Keep Default Setting]
Discrete GPU BOMACO Support [Disabled]
Thunderbolt / USB4 Support [Enabled]
Thunderbolt / USB4 Security Level [No Security]
Thunderbolt / USB4 MMIO Resource [Full Size]
Thunderbolt / USB4 Wake Up Command [GO2SX Command]
CPU Frequency [0]
CPU Voltage [0]
SMT Control [Auto]
UCLK DIV1 MODE [Auto]
Precision Boost Overdrive [Auto]
VDDG Voltage Control [Auto]
SoC/Uncore OC Mode [Auto]
SoC Voltage [0]
LN2 Mode [Auto]
VDD Misc Control [Auto]
LCLK Frequency Control [Auto]
VDDIO Ctrl [Auto]
VPP Ctrl [Auto]
ASTON
Dark_Angel3000: ↑ 25.01.2023 18:52 ASTON
Дякую :beer:
yupi
как 7600х греется?
справится ли такой кулерок на 1200рпм?
https://www.jonsbo.com/en/products/HX6200DWhite.html
manbearboar
yupi: ↑ 30.01.2023 14:33 как 7600х греется?
Тут требуется "понять и простить", что практически с любым воздухом будет 95 градусов под полной нагрузкой, а дальше от кулера уже зависит не температура, а рабочие частоты, которые в реальности падают довольно символически на более слабых кулерах.
yupi
да уж, темпы совсем не радуют.
подождем рефреша какого-то :)
Andikho
manbearboar
yupi
Ось вам цікаве дослідження, де не буде 95 градусів і втрати швидкодії... Якщо ви не переслідуєте топ-1 хвбота і вам потрібно просто 24/7 система, яка не знаходиться на межі кип'ятіння води - все в рамках погрішностей (<10%)
Stray
ну що, оголосили ціни й наявність x3d версій - тиць
Mixx
yupi
В біосі більшості плат є можливість поставити замість 95 градусів ліміт на 70-80, воно на 150-200мгц знизить частоту і напругу і будете мати холодний камінь майже без втрати швидкодії :beer:
Timedemo
Andikho: ↑ 01.02.2023 22:05 manbearboar
yupi
що поганого в темпі 95 градусів, якщо завод виробник запроектував цю темпу робочу.
Andikho
Timedemo: ↑ 04.02.2023 20:11що поганого в темпі 95 градусів
Нічого, якщо ви використовуєте комп як обігрівач і вам норм мати споживання +80 ватт заради 3-5% приросту швидкодії :rotate:
Timedemo
Andikho: ↑ 04.02.2023 20:15
при чому тут обігрівач?
купити процессор за 500-700 баксів, щоб його притупити, заради 40-50вт?
Andikho
Timedemo: ↑ 04.02.2023 20:27щоб його притупити
По-перше не 40-50 а 80-100.
По-друге, втративши на цьому від нічого до 3-5%.
Так, дійсно, краще хай воно кукурузить на 95 градусах :gigi:
Timedemo
Andikho: ↑ 04.02.2023 20:30
ясно. а не пробували брати проци проще? чи це такий фетіш новий? доречі, там якщо відключити половину ядер, можна ще зменшити споживання.
terminahtor
Timedemo
Можна взагалі ПК не включати, суцільна економія.
Andikho
Timedemo: ↑ 04.02.2023 20:33ясно. а не пробували брати проци проще?
Чоловіче, а не пробував спочатку подивитись на співвідношення швидкодії стокового 7900х зі споживанням 160 і 7950х зі споживанням 105? Подивись, а потім висирай свої фантазії про відключеняя половини ядер. Ти собі вже по ходу щось відключив, здоровий глузд, наприклад. :rotate:
Timedemo
Andikho: ↑ 04.02.2023 20:35
Здоровий глузд, це підбирати залізо під правильні задачі, на брети ТОП проци і затуплювати під го..новідик.
Дивився я відео, і що далі? я не можу висловити свою думку? чи ти тут пуп землі? відкрий свій форум, фанів сбери, і хай тільки там тебе слухають.
Andikho
Timedemo
Це не я почав виказувати "розумні" думки про дешевший проц і тп.
Щодо відіка, то уяви собі, не всі люди задротсвують в ігри - декому потрібен хороший проц, а відік - не дуже. Не варто свої запити проектувати на всіх оточуючих (це так, дружня порада). На тому дискусію вважаю вичерпаною. Гарного вечора
Timedemo
Andikho: ↑ 04.02.2023 20:46 Timedemo
Ти так нічого і не зрозумів.
yupi
Timedemo: ↑ 04.02.2023 20:33не пробували брати проци проще
Куда уж проще, чем 7600х? :rotate:
