AMD Catalyst 13.1: что нового?
Chihonya
Юрій
А чем вас семерка то не устраивает? Недоделка эта 8-ка...
anatolikostis
0xffffh:anatolikostis
Windows\System32\DriverStore\FileRepository - здесь могут дрова оставаться, можно вручную удалить.
Краткая инструкция
1. Go to Add/Remove Programs
2. Uninstall the Catalyst Install manager (Express Uninstall)
3. Reboot the computer and log back into windows as normal
4. Go to folder options and select “show hidden files and folders”
The next part of the guide will remove all ATi/AMD files and folders from the computer.
5. Go to your C drive and remove the “AMD” folder
6. Double click the “Program Data” folder (Normally hidden) and remove all ATi/AMD folders
7. Go back to C and double click “Program Files” and remove all ATi/AMD folders
8. Go back to C and double click “Program Files (x86)” and remove all ATi/AMD folders
9. Go back to C and double click “Users”
10. Access the name of your windows profile and double click “AppData” (Normally hidden)
11. Check the “Local”, “LocalLow” and “Roaming” folders for any ATi/AMD folders and remove them.
12. Go back to “Users” and check the “Default” folder (Normally hidden)
13. Double click “AppData” (Normally hidden)
14. Check the “Local” and “Roaming” folders for any ATi/AMD folders and remove them.
The next part of the guide will remove registry entries left by the AMD drivers.
15. Close everything down and go back to your desktop
16. Click start, then type “regedit”.
17. Click “HKEY_CURRENT_USER” and extend the folder
18. Click “Software” and extend the folder
19. Remove all AMD and ATi Folders
20. Click “Wow6432Node” and extend the folder (Within the software folder)
21. Remove the “AMD” folder
22. Click “HKEY_LOCAL_MACHINE” and extend the folder
23. Click “SOFTWARE” and extend the folder
24. Remove all AMD and ATi Folders
25. Click “Wow6432Node” and extend the folder
26. Remove all AMD and ATi Folders
27. Click “HKEY_USERS” and extend the folder
28. Click “.DEFAULT” and extend the folder
29. Click “Software” and extend the folder
30. Remove all AMD and ATi folders
31. Click “S-1-5-18” and extend the folder
32. Click “Software” and extend the folder
33. Remove all AMD and ATi folders
34. Click “S-1-5-21-1632250243-966907716-928185508-1000” and extend the folder
35. Click “Software” and extend the folder
36. Remove all AMD and ATi Folders
37. Close down regedit and empty your recycle bin
38. Undo the folder options change to hide the hidden folders
39. Reboot
40. Install your AMD/Nvidia drivers and reboot
Вин7 не такая простая штучка ;)
Samson
Mechanical:Jonnik, а аватарку можно анимировать ?
Жинка анимирует вам, а это вымя не настоящее, отстой.
viperest1
В темі про драйвера Каталіст також людина написала проте, що піднялася температура карти з 12 версією драйвера,значить мій випадок не поодинокий.
Lerty
Поставил 13.1, до этого были 12.11. На HD 7770 Батла 3 в мультиплеере заметно плавнее идет, фпс почти не изменился, но плавность реально заметна, никаких подтормаживаний, играю на ультра. Вылетов не было. Вроде для 7 серии дрова хорошие. Буду еще тестить.
Scharfschutze
viperest1:В темі про драйвера Каталіст також людина написала проте, що піднялася температура карти з 12 версією драйвера,значить мій випадок не поодинокий.
Может еще с энергосбережением, что-то или конфликты с разгонными утилитами. Пробуй удалить, вычистить и поновой поставить.
sashok-1982
Откуда: Широта: 50° 26'N, Долгота: 30° 31'E. город герой Киев, Позняки
у меня картинка прыгает в играх и в браузере
viperest1
Scharfschutze
я зараз поставив 13 версію, поки ґлюків не замітив-і нехай працює+температури не змінилися ;) . Ну і не хочу ремонтувати те , що і так працює,бо "пацієнт" працює,боюся може і не вижити :gigi: . Реєстр почистив коли ставив ці,думаю проблем не буде,а коли щось напишу :super:
Gnok
Не дай бог меня черт дёрнет ещё раз поставить дрова от амуды :censoured: :mad:
Целое утро убил, пытаясь их удалить :banghead:
После удаления из списка программ, драйвер просит перезагрузится, комп перезагружается и что я вижу - он не удален, зато в списке программ его нету. Uninstall tool, Driver Sweeper не помогли.
anatolikostis: Краткая инструкция
скрытый текст: показать
Спасибо за инструкцию, но тоже не помогло. Драйвер тупо не удаляется. После всех манипуляций он даже умудряется видео воспроизводить :mad: :banghead:
Пробовал поверху накатывать старые дрова - 12.11, даже 12.6 - частота карточки всё равно не сбрасывается, только после сброса в номинал начала скидываться. Сейчас стоят 12.6 - такие артефакты мне сыпет что я даже еле вижу как сообщение набирать всё тупо дёргается :banghead:
SERGBILL
так может это карточке кирдык?
и проблем с удалением я не вижу, именно после чистки свипером после перезагрузки разрешение 640х480 и никакого намёка на драйвер.
Samson
Спасибо вам хлопцы за всё! Если бы не вы, то и я бы... :beer:
Scharfschutze
Gnok
sashok-1982:у меня картинка прыгает в играх и в браузере
http://forums.overclockers.ru/viewtopic.php?t=427047" target="_blank
там в FАQ есть ответ, что делать.
anatolikostis
Gnok: Спасибо за инструкцию, но тоже не помогло. Драйвер тупо не удаляется. После всех манипуляций он даже умудряется видео воспроизводить :mad: :banghead:
Запомни одно: эта тварь ОСь7 очень хорошо помнит, откуда ты ставил прошлый раз дрова и позапрошлый тоже :D Поэтому после процедуры стандартного удаления и до перезагрузки, нужно потереть папки с распакованным инстальником Catalyst, это путь C:/AMD/Catalyst 13.1 например.
Только после деинсталяции и удаления папок можно перегружать винду, после ребута заходим в безопасный режим и добиваем хвосты Driver Sweeper-ом.
AdaMbl4
Chihonya: А чем вас семерка то не устраивает? Недоделка эта 8-ка...
8-ка как 8-ка. Ничего недоделанного в ней не вижу.
Насчёт дров... Проблем с видео не наблюдаю, и mkv, и avi, и vob - всё нормально, квадратов не заметил, плеер Light Alloy. В Батле 3-м изменений нет, в Haven Benchmark'e + 40 баллов. Система из конфига.
Всё в сравнении с beta11
Gnok
SERGBILL:так может это карточке кирдык?
неа
SERGBILL:именно после чистки свипером после перезагрузки разрешение 640х480 и никакого намёка на драйвер.
сегодня обновлю свипер и попробую ещё. пока что поставил 12.1, ничего не "скачет"
У меня кстати после перезагрузки разрешение 1920*1080, почему я сразу и понял что дрова не удаляются
Scharfschutze:http://forums.overclockers.ru/viewtopic.php?t=427047
Спасибо, после работы гляну чё там
anatolikostis:потереть папки с распакованным инстальником Catalyst, это путь C:/AMD/Catalyst 13.1 например.
Я эту папку удаляю сразу после установки дров.
anatolikostis
Gnok
Верно подметили тебе, что твоя ОСь шибко вумная и не отпускает драйвера.
Если после "правильной" деинсталляции при входе в систему нет "мыла", значит удалилось неверно. :beer:
Scharfschutze
Бывает после удаления каталиста и перезагрузки семерка автоматом ставит встроенный в нее vga ati драйвер.
snegurrrka
Atiman Uninstaller всё удаляет очень хорошо и сразу, если не хватает удаления через установщик АМД.
Adamantium
Ghost
Scharfschutze:Бывает после удаления каталиста и перезагрузки семерка автоматом ставит встроенный в нее vga ati драйвер.
Отключить автоматическую установку драйверов устройств? :spy:
