Здравствуйте!
Помогите подобрать процессор к ноутбуку.
Хочу поменять на подходящий для моей системы охлаждения / питания более мощный и производительный процессор.
Вот характеристика поутбука.
Рrocessors Information
Socket 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Mobile Core 2 Duo T6670
Codename Penryn
Specification Intel(R) Core(TM)2 Duo CPU T6670 @ 2.20GHz
Package (platform ID) Socket P (478) (0x7)
CPUID 6.7.A
Extended CPUID 6.17
Core Stepping R0
Technology 45 nm
Core Speed 2193.6 MHz
Multiplier x Bus Speed 11.0 x 199.4 MHz
Base frequency (cores) 199.4 MHz
Base frequency (ext.) 199.4 MHz
Rated Bus speed 797.7 MHz
Stock frequency 2200 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x
Microcode Revision 0xA0C
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 1 thread(s)
Cache descriptor Level 1, I, 32 KB, 1 thread(s)
Cache descriptor Level 2, U, 2 MB, 2 thread(s)
FID/VID Control yes
FID range 6.0x - 11.5x
Max VID 1.200 V
IBRS not supported
IBPB not supported
STIBP not supported
RDCL_NO no
IBRS_ALL not supported
Temperature 0 44 degC (111 degF) (Core #0)
Temperature 1 46 degC (114 degF) (Core #1)
Clock Speed 0 2193.58 MHz (Core #0)
Clock Speed 1 2193.58 MHz (Core #1)
Core 0 max ratio (effective) 11.5
Core 1 max ratio (effective) 11.5
Chipset
Northbridge Intel GM45/GM47 rev. 07
Southbridge Intel 82801IM (ICH9-M) rev. 03
Memory Type DDR3
Memory Size 8 GBytes
Channels Dual, (Symmetric)
Memory Frequency 399.0 MHz (1:2)
CAS# latency (CL) 6.0
RAS# to CAS# delay (tRCD) 6
RAS# Precharge (tRP) 6
Cycle Time (tRAS) 14
Host Bridge 0x2A40
Drive
Name GOODRAM
Revision SAFM12.2
Serial A1D4076506F100169569
Capacity 111.8 GB
Type Fixed, SSD
Bus Type SATA (11)
Features SMART, TRIM
Volume c:\, 111.3 GBytes (22.2 percent available)
Зарание спасибо!
Вот остановился на таких:
https://ark.intel.com/products/37033/In ... 66-MHz-FSB
или
https://ark.intel.com/products/39312/In ... 66-MHz-FSB
Есть ли какие то замечания к выбору?
Подойдут или слишком мощные?
Или есть еще критерии кроме сокета?
Процессор для HP620
nds156
