Подскажите что это за модули памяти стоят в HX432C16PB3K2/32
avshkabura
GoToHell
пес Патрон
- cjr выглядит так
Отправлено спустя 2 минуты 26 секунд:
Но, говорят, похож
8Gbit JJR/JFR
Characteristics: Suspiciously similar to CJR. Tested DDR4-2666 OEM stick did 3600 18-19-19-40 1.2V on ryzen (cheap 1DPC board), and booted 3733 unstable. No noticeable voltage scaling going to 1.45V.
Found on: Some dell alienware OEM systems use hynix OEM sticks carrying this IC. Not documented on the hynix website.
Platform preferences: Certainly gets on fine with ryzen, be surprising if it doesn't like Intel *lake. Presumably has issues on X99.
Recommended for: Might be a good value daily option if you find a cheap used set.
Alexey1977
avshkabura
скачайте Thaiphoon Burner и гляньте что у вас за чипы памяти
