Дамп
Код: Виділити все
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64 Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [D:\Downloads\MEMORY.DMP] Kernel Summary Dump File: Only kernel address space is available Symbol search path is: C:\Windows\Symbols Executable search path is: Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64 Product: WinNt, suite: TerminalServer SingleUserTS Built by: 7601.17514.amd64fre.win7sp1_rtm.101119-1850 Machine Name: Kernel base = 0xfffff800`03a68000 PsLoadedModuleList = 0xfffff800`03cade90 Debug session time: Sun Dec 21 12:44:04.936 2014 (UTC + 2:00) System Uptime: 0 days 0:14:23.123 Loading Kernel Symbols ............................................................... ................................................................ ................................... Loading User Symbols PEB is paged out (Peb.Ldr = 000007ff`fffdf018). Type ".hh dbgerr001" for details Loading unloaded module list ........ The context is partially valid. Only x86 user-mode context is available. The wow64exts extension must be loaded to access 32-bit state. .load wow64exts will do this if you haven't loaded it already. ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck A, {fffffa80651cd600, 2, 1, fffff80003b0e970} Probably caused by : Unknown_Image ( nt!MiReplenishPageSlist+c0 ) Followup: MachineOwner --------- 16.0: kd:x86> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* IRQL_NOT_LESS_OR_EQUAL (a) An attempt was made to access a pageable (or completely invalid) address at an interrupt request level (IRQL) that is too high. This is usually caused by drivers using improper addresses. If a kernel debugger is available get the stack backtrace. Arguments: Arg1: fffffa80651cd600, memory referenced Arg2: 0000000000000002, IRQL Arg3: 0000000000000001, bitfield : bit 0 : value 0 = read operation, 1 = write operation bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status) Arg4: fffff80003b0e970, address which referenced memory Debugging Details: ------------------ WRITE_ADDRESS: fffffa80651cd600 CURRENT_IRQL: 0 FAULTING_IP: nt!MiReplenishPageSlist+c0 fffff800`03b0e970 f00fba6b1000 lock bts dword ptr [ebx+10h],0 DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT BUGCHECK_STR: 0xA LAST_CONTROL_TRANSFER: from 0000000000000000 to 0000000000000000 STACK_TEXT: 00000000 00000000 00000000 00000000 00000000 0x0 STACK_COMMAND: .bugcheck ; kb FOLLOWUP_IP: nt!MiReplenishPageSlist+c0 fffff800`03b0e970 f00fba6b1000 lock bts dword ptr [ebx+10h],0 SYMBOL_NAME: nt!MiReplenishPageSlist+c0 FOLLOWUP_NAME: MachineOwner DEBUG_FLR_IMAGE_TIMESTAMP: 0 IMAGE_NAME: Unknown_Image BUCKET_ID: INVALID_KERNEL_CONTEXT MODULE_NAME: Unknown_Module Followup: MachineOwner ---------
А спустя пару дней еще BSOD, и опять тест и опять ошибка, даже две.
Решаю обновить биос, ведь уже новые версии как минимум две пропустил. Было 1707 , обновил до последнего 2103. Последние несколько версий только "improves system stability" ,а у меня с первой версии все хорошо работало и обновлялся чисто для собственного спокойствия.
Опять тест и опять ошибки на хmp профилях, причем на 2400MHz сразу много ошибок, а вот 2133MHz может быть одна или две, а может и не быть.
Сейчас работает на 1866MHz вроде стабильно. Далее никаких манипуляций не производил.
Первым делом я предполагаю надо протестировать память на другом компьютере. Но такого компа нет.
Есть ли смысл откатится на старый биос, до появления Haswell Refresh ибо есть подозрения в новых версиях?
Прошу помощи в решении в дальнейшем расследовании этого триллера. Каждый раз включая комп боюсь словить BSOD больше чем встретить Чужого в игре.
P.S. Как же так брендовый Kingston c пожизненной гарантией осыпался? Ай-я-йай
