проц 6750
мать P35DQ6
Б.П. HitePower 560w
память Corsair XMS2 (4-4-4-12)
комп не проходит тест CPU может че подскажете ниже може че в настройках
3DMark Score 8248 3DMarks
SM2.0 Score 4481
HDR/SM3.0 Score 5 K
CPU Score 1188
Game Score N/A
GT1 - Return To Proxycon 34.700 FPS SM2.0 Graphics Tests
GT2 - Firefly Forest 39.988 FPS SM2.0 Graphics Tests
CPU1 - Red Valley 0.374 FPS CPU Tests
CPU2 - Red Valley 0.604 FPS CPU Tests
HDR1 - Canyon Flight 47.099 FPS HDR/SM3.0 Graphics Tests
HDR2 - Deep Freeze 55.498 FPS HDR/SM3.0 Graphics Tests
Fill Rate - Single-Texturing 7618.769 MTexels/s Feature Tests
Fill Rate - Multi-Texturing 11778.339 MTexels/s Feature Tests
Pixel Shader 341.897 FPS Feature Tests
Vertex Shader - Simple 280.318 MVertices/s Feature Tests
Vertex Shader - Complex 191.075 MVertices/s Feature Tests
Shader Particles (SM3.0) 124.875 FPS Feature Tests
Perlin Noise (SM3.0) 172.957 FPS Feature Tests
8 Triangles 17.021 MTriangles/s Batch Size Tests
32 Triangles 66.702 MTriangles/s Batch Size Tests
128 Triangles 263.558 MTriangles/s Batch Size Tests
512 Triangles 356.944 MTriangles/s Batch Size Tests
2048 Triangles 342.734 MTriangles/s Batch Size Tests
32768 Triangles 344.129 MTriangles/s Batch Size Tests
Manufacturer Intel
Family x86 Family 6 Model 15 Stepping 11
Architecture 64-bit
Internal Clock 2666 MHz
Internal Clock Maximum 2667 MHz
External Clock 333 MHz
Socket Designation Socket 775
Type Central
Upgrade
MultiCore 2 Processor Cores
HyperThreadingTechnology Available - Disabled
Capabilities MMX, CMov, RDTSC, SSE, SSE2, SSE3, PAE, NX
Version x86 Family 6 Model 15 Stepping 11
DirectX Info
Version 9.0c
Long Version 4.09.00.0904
DirectDraw Info
Version 4.07.00.0700
Primary Device ATI Radeon HD 2900 XT
Cooperative Adapters ЛОЖЬ
Display Devices
Display Device
Description ATI Radeon HD 2900 XT
Manufacturer
Total Local Video Memory 530 MB
Total Local Texture Memory 530 MB
AGP Aperture Size 490 MB
Motherboard Info
Supported Slot Types ISA, PCI
Manufacturer Gigabyte Technology Co., Ltd.
Model P35-DQ6
Version
BIOS Vendor Award Software International, Inc.
BIOS Version GBT - 42302e31
BIOS Release Date 26/10/07
BIOS Properties Plug and Play, Flash
В 3DMark06 в тесте СРU-1FPS помогите че делать 6750 видео HIS 2900xt
MaG!STeR
Это нормально, на Q6600 тоже показывает 1-3FPS, в этом тесте на современных процах ты не увидишь сногсшибающего фреймрейта, так что успокойся.
an_on
спасибо но терзают смутные сомнения 8248 мне кажется всеравно маловато может бить што нехватает питания видеокарте она запитана дополнительными двома 6 пиновыми кабелями а нужно один 6 а второй 8 пиновый бо когда играю в игры через USB даже телефон незаряжаеться
zenka
А при каком разришении проходил тест?
RomanLV
А мне это кажется ненормальнымan_on:CPU Score 1188
Spawny
Вот мой Е6750 в номинале...
Эти тесты не нужны, у тебя крякнутый марк, нужен не крякнутый.... ничего не меняя, у не крякнутого ничего и не меняется, проходи тест.an_on:Fill Rate - Single-Texturing 7618.769 MTexels/s Feature TestsFill Rate - Multi-Texturing 11778.339 MTexels/s Feature TestsPixel Shader 341.897 FPS Feature TestsVertex Shader - Simple 280.318 MVertices/s Feature TestsVertex Shader - Complex 191.075 MVertices/s Feature TestsShader Particles (SM3.0) 124.875 FPS Feature TestsPerlin Noise (SM3.0) 172.957 FPS Feature Tests8 Triangles 17.021 MTriangles/s Batch Size Tests32 Triangles 66.702 MTriangles/s Batch Size Tests128 Triangles 263.558 MTriangles/s Batch Size Tests512 Triangles 356.944 MTriangles/s Batch Size Tests2048 Triangles 342.734 MTriangles/s Batch Size Tests32768 Triangles 344.129 MTriangles/s Batch Size Tests
an_on
Width 1280
Height 1024
3DMark Score 8436 3DMarks
SM2.0 Score 4624
HDR/SM3.0 Score 5 K
CPU Score 1212
GT1 - Return To Proxycon 35,968 FPS
GT2 - Firefly Forest 41,093 FPS
CPU1 - Red Valley 0,381 FPS
CPU2 - Red Valley 0,616 FPS
HDR1 - Canyon Flight 47,637 FPS
HDR2 - Deep Freeze 56,881 FPS
прошол разрешение стандартное 1280*1024 видео( core clok 743 memory clok 828) может частоты увеличить
Height 1024
SM2.0 Score 4624
HDR/SM3.0 Score 5 K
CPU Score 1212
Spawny
an_on
Смотри мой скрин, у меня в цпу тесте 2700
an_on
вроде уже повеселей но до 2700 пока не дотягую CPU 2317 всуме по 3dMark 10308вложил скрин ниже мо че подскажете хочу побольше попробую проц розогнать
- Вкладення
Spawny
Патч на марк поставь...
