Thief 4
Shosya
Потрібна допомога, може в когось була така проблема, у 8-ій главі тупо перестала зберігатись і мало того, після кат-сцени завантажує на початок глави (зміна дати не допомагає, якесь враження що після переходу на літній час таке почалось тому що останні зберігання датовані 31.03).
MaG!STeR
Последнее обновление ставь (1.4), там исправлен этот баг.
We have just made public a new version of the PC version of Thief, v1.4 build 4133.3.
This patch will address the following issues.
- Fixed an issue where when finishing a chapter, the user would be brought back to the start. That primarily occurred around the April 1st.
- Fixed several audio issues, including:
- Issues with sound occlusion, being able to hear NPCs talking through walls.
- Issues with music being relatively loud in several chapters.
- Issue with credits music.
- Fixed an issue with shadows that would occur on certain Nvidia and Intel GPUs.
- Fixed issues where the quicksave would be overwritten.
- Quicksaves now occupy a seperate slot internally and in the loading menu. To load a quicksave press F9 or go into the Load menu and select the Quicksave Slot.
- Increased dedicated texture memory pool size for Intel GPUs.
- Fixed an issue where several documents were missing.
- Fixed an issue where the Spectral Aspect trinket had no effect.
- Fixed an issue where player was unable to look around while using the handwheel.
- Button prompts in the station screens now update automatically based on the user input method.
- Several minor bug fixes.
Shosya
MaG!STeR R
Дякую :beer: (чого я його ненагуглив,не зрозуміло :-/ )
