xinput1_3.dll при запуске некоторых игр
Обсуждение программ
Rean1mation
Загуглил, сказали скачать Direct X и обновить его. Качнул, но обновить не дает, выскакивает ошибка в самом конце.
Под спойлером логи ошибки. Видео Gigabyte GTX 660. Дрова последние.
[11/09/14 15:56:51] module: dxupdate(Nov 19 2010), file: dxupdate.cpp, line: 5738, function: DirectXUpdateInstallPlugIn
Failed API: SetupIterateCabinet()
Error: (1224) - Запрошенную операцию нельзя выполнить для файла с открытой пользователем сопоставленной секцией.
Unable to iterate through C:\Windows\system32\DirectX\WebSetup\Apr2005_d3dx9_25_x64.cab. The file may be damaged.
[11/09/14 15:56:51] module: dsetup32(Sep 4 2009), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
DirectXUpdateInstallPlugIn() failed.
[11/09/14 15:56:51] module: dsetup32(Sep 4 2009), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[11/09/14 15:56:52] module: dsetup32(Sep 4 2009), file: dsinline.h, line: 302, function: DXRemoveFile
Unable to remove C:\Users\User\AppData\Local\Temp\DXD54B.tmp.
[11/09/14 15:56:52] module: dsetup32(Sep 4 2009), file: inline.h, line: 220, function: CleanUpDirectory
Unable to remove: C:\Users\User\AppData\Local\Temp\DXD54B.tmp\infinst.exe which is locked, reason = 5.
[11/09/14 16:47:57] module: dxupdate(Nov 19 2010), file: dxupdate.cpp, line: 5738, function: DirectXUpdateInstallPlugIn
Unable to iterate through C:\Windows\system32\DirectX\WebSetup\Jun2005_d3dx9_26_x64.cab. The file may be damaged.
[11/09/14 16:47:57] module: dsetup32(Sep 4 2009), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[11/09/14 16:47:57] module: dsetup32(Sep 4 2009), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[11/09/14 16:47:58] module: dsetup32(Sep 4 2009), file: dsinline.h, line: 302, function: DXRemoveFile
Unable to remove C:\Users\User\AppData\Local\Temp\DX89AC.tmp.
[11/09/14 16:47:58] module: dsetup32(Sep 4 2009), file: inline.h, line: 220, function: CleanUpDirectory
Unable to remove: C:\Users\User\AppData\Local\Temp\DX89AC.tmp\infinst.exe which is locked, reason = 5.
[11/09/14 16:50:31] module: dxupdate(Nov 19 2010), file: dxupdate.cpp, line: 5738, function: DirectXUpdateInstallPlugIn
Unable to iterate through C:\Windows\system32\DirectX\WebSetup\Aug2005_d3dx9_27_x64.cab. The file may be damaged.
[11/09/14 16:50:31] module: dsetup32(Mar 30 2011), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[11/09/14 16:50:31] module: dsetup32(Mar 30 2011), file: setup.cpp, line: 1727, function: CSetup::SetupForDirectX
[11/09/14 16:50:32] module: dsetup32(Mar 30 2011), file: dsinline.h, line: 302, function: DXRemoveFile
Unable to remove C:\Users\User\AppData\Local\Temp\DXF441.tmp.
[11/09/14 16:50:32] module: dsetup32(Mar 30 2011), file: inline.h, line: 331, function: CleanUpDirectory
Unable to remove: C:\Users\User\AppData\Local\Temp\DXF441.tmp\infinst.exe which is locked, reason = 5.
[11/09/14 16:55:02] module: dxupdate(Nov 19 2010), file: dxupdate.cpp, line: 5738, function: DirectXUpdateInstallPlugIn
Unable to iterate through C:\Windows\system32\DirectX\WebSetup\Dec2005_d3dx9_28_x64.cab. The file may be damaged.
[11/09/14 16:55:02] module: dsetup32(Sep 4 2009), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[11/09/14 16:55:02] module: dsetup32(Sep 4 2009), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[11/09/14 16:55:04] module: dsetup32(Sep 4 2009), file: dsinline.h, line: 302, function: DXRemoveFile
Unable to remove C:\Users\User\AppData\Local\Temp\DX1893.tmp.
[11/09/14 16:55:04] module: dsetup32(Sep 4 2009), file: inline.h, line: 220, function: CleanUpDirectory
Unable to remove: C:\Users\User\AppData\Local\Temp\DX1893.tmp\infinst.exe which is locked, reason = 5.
[11/09/14 16:59:35] module: dxupdate(Nov 19 2010), file: dxupdate.cpp, line: 5738, function: DirectXUpdateInstallPlugIn
Unable to iterate through C:\Windows\system32\DirectX\WebSetup\Feb2006_d3dx9_29_x64.cab. The file may be damaged.
[11/09/14 16:59:35] module: dsetup32(Sep 4 2009), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[11/09/14 16:59:35] module: dsetup32(Sep 4 2009), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
[11/09/14 16:59:36] module: dsetup32(Sep 4 2009), file: dsinline.h, line: 302, function: DXRemoveFile
Unable to remove C:\Users\User\AppData\Local\Temp\DXBB63.tmp.
[11/09/14 16:59:36] module: dsetup32(Sep 4 2009), file: inline.h, line: 220, function: CleanUpDirectory
Unable to remove: C:\Users\User\AppData\Local\Temp\DXBB63.tmp\infinst.exe which is locked, reason = 5.
[11/09/14 17:06:04] module: dxupdate(Nov 19 2010), file: dxupdate.cpp, line: 5738, function: DirectXUpdateInstallPlugIn
Unable to iterate through C:\Windows\system32\DirectX\WebSetup\Feb2006_XACT_x64.cab. The file may be damaged.
[11/09/14 17:06:04] module: dsetup32(Mar 30 2011), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[11/09/14 17:06:04] module: dsetup32(Mar 30 2011), file: setup.cpp, line: 1727, function: CSetup::SetupForDirectX
[11/09/14 17:06:05] module: dsetup32(Mar 30 2011), file: dsinline.h, line: 302, function: DXRemoveFile
Unable to remove C:\Users\User\AppData\Local\Temp\DXAD11.tmp.
[11/09/14 17:06:05] module: dsetup32(Mar 30 2011), file: inline.h, line: 331, function: CleanUpDirectory
Unable to remove: C:\Users\User\AppData\Local\Temp\DXAD11.tmp\infinst.exe which is locked, reason = 5.
[11/09/14 17:10:33] module: DXWSetup(Mar 30 2011), file: dxwsetup.cpp, line: 229, function: CDXWSetup::InitInstallEngine
Sections are not initialized.
[11/09/14 17:10:33] module: DXWSetup(Mar 30 2011), file: psheets.cpp, line: 705, function: PreinstDlgProc
CDXWSetup::InitInstallEngine() failed.
[11/09/14 17:12:06] module: dxupdate(Nov 19 2010), file: dxupdate.cpp, line: 5738, function: DirectXUpdateInstallPlugIn
Unable to iterate through C:\Windows\system32\DirectX\WebSetup\Apr2006_XACT_x64.cab. The file may be damaged.
[11/09/14 17:12:06] module: dsetup32(Mar 30 2011), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[11/09/14 17:12:06] module: dsetup32(Mar 30 2011), file: setup.cpp, line: 1727, function: CSetup::SetupForDirectX
[11/09/14 17:12:08] module: dsetup32(Mar 30 2011), file: dsinline.h, line: 302, function: DXRemoveFile
Unable to remove C:\Users\User\AppData\Local\Temp\DX3302.tmp.
[11/09/14 17:12:08] module: dsetup32(Mar 30 2011), file: inline.h, line: 331, function: CleanUpDirectory
Unable to remove: C:\Users\User\AppData\Local\Temp\DX3302.tmp\infinst.exe which is locked, reason = 5.
[11/09/14 22:43:15] module: dxupdate(Nov 19 2010), file: dxupdate.cpp, line: 5738, function: DirectXUpdateInstallPlugIn
Unable to iterate through C:\Windows\system32\DirectX\WebSetup\Aug2006_xinput_x64.cab. The file may be damaged.
[11/09/14 22:43:15] module: dsetup32(Mar 30 2011), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[11/09/14 22:43:15] module: dsetup32(Mar 30 2011), file: setup.cpp, line: 1727, function: CSetup::SetupForDirectX
[11/09/14 22:43:17] module: dsetup32(Mar 30 2011), file: dsinline.h, line: 302, function: DXRemoveFile
Unable to remove C:\Users\User\AppData\Local\Temp\DXB95.tmp.
[11/09/14 22:43:17] module: dsetup32(Mar 30 2011), file: inline.h, line: 331, function: CleanUpDirectory
Unable to remove: C:\Users\User\AppData\Local\Temp\DXB95.tmp\infinst.exe which is locked, reason = 5.
[11/09/14 22:45:31] module: dxupdate(Nov 19 2010), file: dxupdate.cpp, line: 5738, function: DirectXUpdateInstallPlugIn
Unable to iterate through C:\Windows\system32\DirectX\WebSetup\Aug2006_XACT_x64.cab. The file may be damaged.
[11/09/14 22:45:31] module: dsetup32(Mar 30 2011), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
[11/09/14 22:45:31] module: dsetup32(Mar 30 2011), file: setup.cpp, line: 1727, function: CSetup::SetupForDirectX
[11/09/14 22:45:32] module: dsetup32(Mar 30 2011), file: dsinline.h, line: 302, function: DXRemoveFile
Unable to remove C:\Users\User\AppData\Local\Temp\DX22CD.tmp.
[11/09/14 22:45:32] module: dsetup32(Mar 30 2011), file: inline.h, line: 331, function: CleanUpDirectory
Unable to remove: C:\Users\User\AppData\Local\Temp\DX22CD.tmp\infinst.exe which is locked, reason = 5.
Jumper007
Зайти в безопасном режиме и установить от имени админа.
c0013r
эту dll надо кинуть в папку с игрой, нужна для геймпадов и т.п., можно взять с комплекта эму x360ce, переименовать если что.
