Нужен совет по "Monitor Asset Manager"
Bulrati
Здравствуйте!
Кто разбирается в проге - Monitor Asset Manager?
Посмотрите пожалуйста мой тест, может что то не так
Monitor #1 [Real-time 0x0100]
Model name............... ASUS PG329
Manufacturer............. AUS
Plug and Play ID......... AUS32F3
Serial number............ n/a
Manufacture date......... 2020, ISO week 1
Filter driver............ None
EDID revision............ 1.4
Input signal type........ Digital (DisplayPort)
Color bit depth.......... 10 bits per primary color
Color encoding formats... RGB 4:4:4, YCrCb 4:4:4, YCrCb 4:2:2
Screen size.............. 710 x 400 mm (32,1 in)
Power management......... Active off/sleep
Extension blocs.......... 1 (CEA/CTA-EXT)
DDC/CI................... Supported
MCCS revison............. 2.2
Display technology....... TFT
Controller............... Novatek 0x0
Firmware revision........ 0.36
Firmware flags........... 0x00000084
Active power on time..... 184 hours
Power consumption........ 0,00 kWh
Current frequency........ 241,20kHz, 165,10Hz
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2,20
Red chromaticity......... Rx 0,685 - Ry 0,305
Green chromaticity....... Gx 0,189 - Gy 0,733
Blue chromaticity........ Bx 0,147 - By 0,054
White point (default).... Wx 0,313 - Wy 0,329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 250-250kHz
Vertical scan range...... 48-165Hz
Video bandwidth.......... 650MHz
CVT standard............. Not supported
GTF standard............. Supported
Preferred timing......... Yes
Native/preferred timing.. 2560x1440p at 165Hz
Modeline............... "2560x1440" 641,500 2560 2581 2613 2660 1440 1451 1459 1461 +hsync -vsync
Detailed timing #1....... 2560x1440p at 60Hz
Modeline............... "2560x1440" 241,900 2560 2608 2640 2720 1440 1467 1475 1481 +hsync -vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1920 x 1080p at 60Hz - VESA STD
1152 x 864p at 75Hz - VESA STD
1280 x 720p at 60Hz - VESA STD
1280 x 960p at 60Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
1920 x 1080p at 120Hz - VESA STD
EIA/CEA/CTA-861 Information
Revision number.......... 3
IT underscan............. Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing #1....... 2560x1080p at 165Hz
Modeline............... "2560x1080" 524,770 2560 2608 2640 2720 1080 1091 1099 1169 +hsync -vsync
Detailed timing #2....... 1280x1440p at 60Hz
Modeline............... "1280x1440" 123,700 1280 1288 1320 1390 1440 1467 1475 1481 +hsync -vsync
Detailed timing #3....... 2560x1440p at 144Hz
Modeline............... "2560x1440" 592,500 2560 2581 2613 2666 1440 1443 1448 1543 +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
640 x 480p at 60Hz - Default (4:3, 1:1)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
720 x 576p at 50Hz - EDTV (4:3, 16:15)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
1440 x 480p at 60Hz - DVD (4:3, 4:9)
1440 x 480p at 60Hz - DVD (16:9, 16:27)
1440 x 576p at 50Hz - DVD (4:3, 8:15)
1440 x 576p at 50Hz - DVD (16:9, 32:45)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48/96 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE video capability data
CE scan behavior......... Not supported
IT scan behavior......... Not supported
PT scan behavior......... Not supported
RGB quantization range... Selectable (via AVI YQ)
YCC quantization range... Selectable (via AVI YQ)
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.0.0.0
Maximum TMDS clock....... 165MHz
IEEE registration number. 0x00001A
CEC physical address..... 0.2.0.3
Supports AI (ACP, ISRC).. No
Supports 48bpp........... No
Supports 36bpp........... Yes
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... No
Supports dual-link DVI... No
Maximum TMDS clock....... 825MHz
Audio/video latency (p).. n/a
Audio/video latency (i).. n/a
HDMI video capabilities.. No
Data payload............. 1A0000020330A5000576327632
CE colorimetry data
xvYCC601 support......... No
xvYCC709 support......... No
sYCC601 support.......... No
AdobeYCC601 support...... No
AdobeRGB support......... No
BT2020CYCC support....... Yes
BT2020YCC support........ Yes
BT2020RGB support........ Yes
Metadata profile flags... 0x01
HDR static metadata
SDR luminance............ Yes
HDR luminance............ Yes
SMPTE ST2084............. Yes
Hybrid log............... No
Data payload............. 060701767632
Report information
Date generated........... 09.02.2023
Software revision........ 2.91.0.1043
Data source.............. Real-time 0x0100
Operating system......... 10.0.19045.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,06,B3,F3,32,00,00,00,00,01,1E,01,04,B5,47,28,78,3B,4B,F5,AF,4E,30,BB,25,
0D,50,54,BF,CF,00,D1,C0,71,4F,81,C0,81,40,81,80,95,00,B3,00,D1,FC,96,FA,00,64,A0,A0,15,50,15,20,
B8,00,C4,8F,21,00,00,1A,7E,5E,00,A0,A0,A0,29,50,30,20,B8,04,C4,8F,21,00,00,1A,00,00,00,FD,00,30,
A5,FA,FA,41,01,0A,20,20,20,20,20,20,00,00,00,FC,00,41,53,55,53,20,50,47,33,32,39,0A,20,20,01,AB,
02,03,3C,71,4D,01,02,03,04,11,12,13,0E,0F,1D,1E,1F,90,23,09,17,07,83,01,00,00,E2,00,C0,65,03,0C,
00,10,00,6D,1A,00,00,02,03,30,A5,00,05,76,32,76,32,E3,05,E0,01,E6,06,07,01,76,76,32,FD,CC,00,A0,
A0,38,59,40,30,20,B8,00,C4,8F,21,00,00,1A,52,30,00,6E,50,A0,29,50,08,20,B8,04,C4,8F,21,00,00,1A,
72,E7,00,6A,A0,A0,67,50,15,20,35,00,C4,8F,21,00,00,1E,00,00,00,00,00,00,00,00,00,00,00,00,00,44
Hardware data
BUS_SLOT = PCI00000.PCI00004.PCI00008.PCI0000C.PCI00010.PCI00014.PCI00018.PCI0001C
00000000 = 3EC28086.20900006.06000007.00000000.00000000.00000000.00000000.00000000
00000008 = 19018086.00100407.06040007.00810010.00000000.00000000.00010100.2000E0E0
000000A0 = A2AF8086.02900406.0C033000.00800000.F7230004.00000000.00000000.00000000
000000B0 = A2BA8086.00100406.07800000.00800000.FE40F004.00000000.00000000.00000000
000000B8 = A2828086.02B00407.01060100.00000000.F7248000.F724C000.0000F051.0000F041
000000D8 = A2E78086.00100404.060400F0.00810010.00000000.00000000.00020200.200000F0
000000E0 = A2908086.00100404.060400F0.00810010.00000000.00000000.00030300.200000F0
000000E4 = A2948086.00100406.060400F0.00810010.00000000.00000000.00040400.200000F0
000000E8 = A2988086.00100404.060400F0.00810010.00000000.00000000.00050500.200000F0
000000F8 = A2C98086.02000007.06010000.00800000.00000000.00000000.00000000.00000000
000000FA = A2A18086.00000006.05800000.00800000.F7244000.00000000.00000000.00000000
000000FB = A2F08086.00100006.04030000.00002010.F7240004.00000000.00000000.00000000
000000FC = A2A38086.02800003.0C050000.00000000.F724A004.00000000.00000000.00000000
000000FE = 15B88086.00100406.02000000.00000000.F7200000.00000000.00000000.00000000
00000100 = 1F0710DE.00100407.030000A1.00800010.F6000000.E000000C.00000000.F000000C
00000101 = 10F910DE.00100006.040300A1.00800010.F7080000.00000000.00000000.00000000
00000102 = 1ADA10DE.00100406.0C0330A1.00800010.F200000C.00000000.00000000.F204000C
00000103 = 1ADB10DE.00100406.0C8000A1.00800010.F7084000.00000000.00000000.00000000
00000400 = 21421B21.00100406.0C033000.00000010.F7100004.00000000.00000000.00000000
У производителя на сайте указано -
Digital Signal Frequency :
DP: 30~250KHz(H) / 48~165Hz(V)
а у меня -
Это норма? Да и в целом с другими параметрами все ОК?
Спасибо
terminahtor
Здавайте по гарантії, очевидно, що монітор бракований.
Це якісь прикол, чи стьоб?
Bulrati
terminahtor: 19.02.2023 03:31 Здавайте по гарантії, очевидно, що монітор бракований.
Почему очевидно, что не так? Я просто не понимаю
Rex
Bulrati
Что вы хотите увидеть в этом тесте и для каких целей его запустили? Эта штука выводит записанные на заводе параметры.
Монитор может быть убитый (с разбитой матрицей, подсветкой), но он будет выводить свои параметры в эту программу.
В чем вопрос?
Bulrati
Rex: 19.02.2023 10:53 Bulrati
В чем вопрос?
В этом и вопрос, понять насколько правильные "записанные на заводе параметры"
У меня есть определенные проблемы с монитором
Вот человек выше пишет, что моник очевидно бракован, я пытаюсь понять как он это увидел
Rex
Это очень тооонкая шутка, понятная не кажому. Забейте.
Какие?
Все там правильно записано, не переживайте за это.
pelia
Bulrati: 19.02.2023 11:02
В чем вопрос?
Человек выше просто стебется. Какие конкретно у вас проблемы с монитором?
Bulrati
Ранее создавал тему - viewtopic.php?f=11&t=261339
Подключение монитора к другому системнику и замена видеокарты не дали результата
Проблема с монитором или с виндой
Отправлено спустя 1 час 26 минут 29 секунд:
Rex: 19.02.2023 11:09
Какие?
Rex
Bulrati
Теперь понятно о чем речь. Смотрите, вы путаете частоту кадров (фпс) и именно скорость обновления изображения на экране. Оно и при 30 фпс (если они стабильны) должно плавно работать без смазываний (обновление картинки я имею ввиду).
По видео непонятно, но я так понимаю, что проблема именно в замедленном обновлении картинки на мониторе (т.е. большое время отклика пикселей). Подобный эффект можно наблюдать, если пользоваться телефоном на сильном морозе. Экран как бы тупит и медленно перерисовывает картинку. Особенно это заметно на старых устройствах с монохромным экраном.
Если это действительно ваш случай, тогда да, это заводской брак и гарантия. В идеале - найти вживую такой же монитор - друзья, супермаркет электроники и т.д. и сравнить.
Если подтвердится проблема - бодаться с Асусятиной, заказывать независимую экспертизу в стороннем СЦ и намекнуть им про ЗПП и суд.
Bulrati
Rex: 19.02.2023 12:47 Bulrati
Спасибо за ответ
А может быть вариант, что как то криво становится винда? Хотя несколько раз переустанавливал.
Чисто теоретически, флешка может влиять на установку?
Rex
Bulrati
Нет, нет и нет.
Еще раз: ставите чистую, оригинальную винду, последнюю версию драйверов на карту, ставите драйвер на монитор, можно еще обновить прошивку.
https://rog.asus.com/monitors/32-to-34- ... _download/
Делитесь результатом.
Bulrati
Rex: 19.02.2023 13:13 Bulrati
Нет, нет и нет.
ОК. Спасибо за совет
