Asus RT-AX82U постійно ребутає wi-fi
Локальные сети и Интернет
quadrotony
Допоможіть розібратись
інет по кабелю при цьому йде без проблем
тільки вайфай рве пару раз в годину
вже дістало
прошивка остання
в логах теж щось дивне... (останній розрив внизу)
Jun 4 14:15:13 wlceventd: wlceventd_proc_event(657): eth6: Radar detected
Jun 4 14:15:13 cfg_server: cm_updateChanspec call wl_chanspec_changed_action
Jun 4 14:15:13 cfg_server: event: wl_chanspec_changed_action_a101 of eid(67) of cfgs(1630)
Jun 4 14:15:13 cfg_server: current chansp(unit0) is 1003
Jun 4 14:15:13 cfg_server: current chansp(unit1) is e03a
Jun 4 14:15:13 cfg_server: dump exclchans:
Jun 4 14:15:13 cfg_server: old wl0_acs_excl_chans:0x100c,0x190a,0x100d,0x190b,0x100e,0x190c
Jun 4 14:15:13 cfg_server: new wl0_acs_excl_chans:0x100c,0x190a,0x100d,0x190b,0x100e,0x190c
Jun 4 14:15:13 cfg_server: old wl1_acs_excl_chans:0xd070,0xd96e,0xe36a,0xe832,0xe932,0xea32,0xeb32,0xec32,0xed32,0xee32,0xef32,0xe872,0xe972,0xea72,0xeb72,0xec72,0xed72,0xee72,0xef72
Jun 4 14:15:13 cfg_server: new wl1_acs_excl_chans:0xd034,0xd038,0xd03c,0xd040,0xd070,0xd836,0xd936,0xd83e,0xd93e,0xd96e,0xe03a,0xe13a,0xe23a,0xe33a,0xe36a,0xe832,0xe932,0xea32,0xeb32,0xec32,0xed32,0xee32,0xef32,0xe872,0xe972,0xea72,0xeb72,0xec72,0xed72,0xee72,0xef72
Jun 4 14:15:13 cfg_server: wl_chanspec_changed_action: Need to restart acsd due current 5G chanspec is un-available, (cur_5g=e03a)
Jun 4 14:15:13 rc_service: cfg_server 1630:notify_rc restart_acsd
Jun 4 14:15:13 acsd: eth5: Selecting 2g band ACS policy
Jun 4 14:15:17 acsd: eth5: selected channel spec: 0x100a (10)
Jun 4 14:15:17 acsd: eth5: Adjusted channel spec: 0x100a (10)
Jun 4 14:15:17 acsd: acs_set_chspec: 0x100a (10) for reason APCS_INIT
Jun 4 14:15:17 acsd: eth6: Selecting 5g band ACS policy
Jun 4 14:15:21 acsd: eth6: selected channel spec: 0xe07a (116/80)
Jun 4 14:15:21 acsd: eth6: Adjusted channel spec: 0xe07a (116/80)
Jun 4 14:15:21 acsd: acs_set_chspec: 0xe07a (116/80) for reason APCS_INIT
Jun 4 14:15:23 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind F6:A4:6F:87:46:1D, status: 0, reason: Unspecified reason (1), rssi:-67
Jun 4 14:15:23 wlceventd: wlceventd_proc_event(530): eth5: Auth F6:A4:6F:87:46:1D, status: Successful (0), rssi:-67
Jun 4 14:15:23 wlceventd: wlceventd_proc_event(540): eth5: ReAssoc F6:A4:6F:87:46:1D, status: Successful (0), rssi:-67
Jun 4 14:15:25 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind 86:31:96:90:C7:82, status: 0, reason: Disassociated due to inactivity (4), rssi:-69
Jun 4 14:15:25 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind 86:31:96:90:C7:82, status: 0, reason: Previous authentication no longer valid (2), rssi:-69
Jun 4 14:15:26 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind 86:31:96:90:C7:82, status: 0, reason: Unspecified reason (1), rssi:-65
Jun 4 14:15:26 wlceventd: wlceventd_proc_event(530): eth5: Auth 86:31:96:90:C7:82, status: Successful (0), rssi:-65
Jun 4 14:15:26 wlceventd: wlceventd_proc_event(540): eth5: ReAssoc 86:31:96:90:C7:82, status: Successful (0), rssi:-65
Jun 4 14:16:04 wlceventd: wlceventd_proc_event(657): eth6: Radar detected
Jun 4 14:16:05 cfg_server: cm_updateChanspec call wl_chanspec_changed_action
Jun 4 14:16:05 cfg_server: event: wl_chanspec_changed_action_a101 of eid(68) of cfgs(1630)
Jun 4 14:16:05 cfg_server: current chansp(unit0) is 100a
Jun 4 14:16:05 cfg_server: current chansp(unit1) is e32a
Jun 4 14:16:05 cfg_server: dump exclchans:
Jun 4 14:16:05 cfg_server: old wl0_acs_excl_chans:0x100c,0x190a,0x100d,0x190b,0x100e,0x190c
Jun 4 14:16:05 cfg_server: new wl0_acs_excl_chans:0x100c,0x190a,0x100d,0x190b,0x100e,0x190c
Jun 4 14:16:05 cfg_server: old wl1_acs_excl_chans:0xd034,0xd038,0xd03c,0xd040,0xd070,0xd836,0xd936,0xd83e,0xd93e,0xd96e,0xe03a,0xe13a,0xe23a,0xe33a,0xe36a,0xe832,0xe932,0xea32,0xeb32,0xec32,0xed32,0xee32,0xef32,0xe872,0xe972,0xea72,0xeb72,0xec72,0xed72,0xee72,0xef72
Jun 4 14:16:05 cfg_server: new wl1_acs_excl_chans:0xd034,0xd038,0xd03c,0xd040,0xd070,0xd080,0xd836,0xd936,0xd83e,0xd93e,0xd96e,0xd97e,0xe03a,0xe13a,0xe23a,0xe33a,0xe36a,0xe37a,0xe832,0xe932,0xea32,0xeb32,0xec32,0xed32,0xee32,0xef32,0xe872,0xe972,0xea72,0xeb72,0xec72,0xed72,0xee72,0xef72
Jun 4 14:16:05 cfg_server: wl_chanspec_changed_action: Need to restart acsd for AVBL update
Jun 4 14:16:05 rc_service: cfg_server 1630:notify_rc restart_acsd
Jun 4 14:16:05 acsd: eth5: Selecting 2g band ACS policy
Jun 4 14:16:08 acsd: eth5: selected channel spec: 0x100a (10)
Jun 4 14:16:08 acsd: eth5: Adjusted channel spec: 0x100a (10)
Jun 4 14:16:08 acsd: acs_set_chspec: 0x100a (10) for reason APCS_INIT
Jun 4 14:16:08 acsd: eth6: Selecting 5g band ACS policy
Jun 4 14:16:13 acsd: eth6: selected channel spec: 0xe02a (36/80)
Jun 4 14:16:13 acsd: eth6: Adjusted channel spec: 0xe02a (36/80)
Jun 4 14:16:13 acsd: acs_set_chspec: 0xe02a (36/80) for reason APCS_INIT
Jun 4 14:16:43 wlceventd: wlceventd_proc_event(494): eth6: Deauth_ind 42:1C:88:3C:4E:43, status: 0, reason: Unspecified reason (1), rssi:-62
Jun 4 14:16:43 wlceventd: wlceventd_proc_event(530): eth6: Auth 42:1C:88:3C:4E:43, status: Successful (0), rssi:-62
Jun 4 14:16:43 wlceventd: wlceventd_proc_event(559): eth6: Assoc 42:1C:88:3C:4E:43, status: Successful (0), rssi:-62
Jun 4 14:17:09 roamast: sta[86:31:96:90:C7:82] on ap[3C:7C:3F:89:0D:B8], rcpi is 78 and rssi is -71
Jun 4 14:17:18 roamast: sta[86:31:96:90:C7:82] on ap[3C:7C:3F:89:0D:B8], rcpi is 68 and rssi is -76
Jun 4 14:17:24 roamast: sta[86:31:96:90:C7:82] on ap[3C:7C:3F:89:0D:B8], rcpi is 66 and rssi is -77
Jun 4 14:17:34 roamast: sta[86:31:96:90:C7:82] on ap[3C:7C:3F:89:0D:B8], rcpi is 74 and rssi is -73
Klon
CG graphikos fan
quadrotony
вважаю що треба написати самому Асусу\Реддіт Асусу (якщо такий є)\їх соцсеточки, можливо отримаєте відповідь :up:
Shpoker
DFS канал не используй. походу всё работает как нужно)
seraphic
спроси у своих работников по прокачке диабло 4 :lol: они то должны быть в курсе если работают в сфере IT
Adamantium
Ghost
quadrotony
Метод тыка пробовали?
Каналы, ширина, регион, мощность передатчика?
allekss
Очень трудно помочь. Для этого надо знать настройки роутера и провайдера. У меня, например, рвало wifi просто от того, что я случайно оставил в настройках статический ip адрес, вместо динамического. Интернет был, но почему-то только на одном устройстве. Легче пригласить настройщика от провайдера. Обрывы в wifi могут быть также от сильной загруженности окружающего пространства сетями wifi. В этом случае в роутере надо отключить снижение сигнала (обычно, если много сетей, роутеры снижают свой собственный сигнал) и выбрать наиболее свободный канал.
bes
Откатись просто на прошлую прошивку, там у асус сейчас какие то проблемы с новыми прошивками может и тебя задело
Mad Dog
DFS... Роутер бачить якийсь сигнал на DFS частотах та тікає на інші частоти.
https://www.asus.com/ru/support/FAQ/1045936/
